which brake lines after rear drum-disk swap?
Old Feb 23, 2004 | 07:57 PM
chadmasterc's Avatar
Default which brake lines after rear drum-disk swap?
I just put Integra rear disks on my hatch. which rear brake lines should i use?
I am guessin 90-93 integra non-abs or 90-91 crx si.
The ones off of my dx definetly didnt work.
Old Feb 23, 2004 | 08:00 PM
kid-honda's Avatar
Both will work.
Old Feb 23, 2004 | 10:53 PM
michael O's Avatar
Default Re: (kid-honda)
I dont think they have to be non abs. I used 90-93 integ lines but be forewarned they're really long so you're going to have to think about where to mount them. I would rather be using crx si lines tho
Old Feb 24, 2004 | 04:32 AM
virginia_dude's Avatar
Default Re: which brake lines after rear drum-disk swap? (chadmasterc)
I also have a hatch with 90-93 Teg reare trailing arms.. Mine came with properly removed E-brake cables and brake lines. I used both and they fit perfectly, not at all long. Now what is longer I believe are the front lines.
Old Feb 24, 2004 | 10:32 AM
Default Re: which brake lines after rear drum-disk swap? (virginia_dude)
Cool, thanks for all the input everyone. I ordered a set for a crx si today.
Old Feb 24, 2004 | 10:37 AM
EL Vap133's Avatar
I used 90-91 crx si brake lines....
Old Feb 24, 2004 | 11:04 AM
WONG FRIED RICE's Avatar
Default Re: which brake lines after rear drum-disk swap? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">I used 90-91 crx si brake lines.... </TD></TR></TABLE>
yup yup used those on my 88 Si after i converted to disc
Old Feb 24, 2004 | 07:36 PM
GS-Rcivic's Avatar
Default Re: which brake lines after rear drum-disk swap? (JDMB16ACRX)
well i just broke both of my rear fitings now i gotta replace the whole thing. Took me 4+ hours to just take stuff out, damn that was a pain in the ***. Any suggestions
Old Feb 24, 2004 | 07:46 PM
michael O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virginia_dude &raquo;</TD></TR><TR><TD CLASS="quote">I also have a hatch with 90-93 Teg reare trailing arms.. Mine came with properly removed E-brake cables and brake lines. I used both and they fit perfectly, not at all long. Now what is longer I believe are the front lines. </TD></TR></TABLE>
I replaced the brake lines with stainless steel ones so I dont know about them but the e-brake lines were definately longer. Also when I bought the trailing arms one e brake line was broken so I replaced it with one from a 91 integra and both the lines were extremely long compared to the stock crx lines eg. they hung a lot lower. But then again my car is a crx and yours is a hatch...is there any difference in size between them?
Old Feb 24, 2004 | 08:23 PM
fourthgenhatchB17's Avatar
Default Re: which brake lines after rear drum-disk swap? (michaelOlson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson &raquo;</TD></TR><TR><TD CLASS="quote">
I replaced the brake lines with stainless steel ones so I dont know about them but the e-brake lines were definately longer. Also when I bought the trailing arms one e brake line was broken so I replaced it with one from a 91 integra and both the lines were extremely long compared to the stock crx lines eg. they hung a lot lower. But then again my car is a crx and yours is a hatch...is there any difference in size between them?</TD></TR></TABLE>
Yes, there is a difference. The crx and integra e brake cables are different. You will want to use teggy ones on a hatch and crx ones only on the crx. I have a spare set of the crx ones because i have a hatch and had to go and buy teggy ones.
92civicfreak
Jun 2, 2008 03:03 AM
msinsky14
Jun 10, 2007 06:59 PM
WVTURBOCRX
Nov 27, 2005 06:29 PM
SoulSurfer
16
Apr 30, 2004 03:50 PM
alexdog69
Apr 15, 2004 03:28 PM
