Tip on how to take cluster bulb out of socket.
Old Feb 23, 2004 | 06:44 PM
Mires's Avatar
Default Tip on how to take cluster bulb out of socket.
Does anyone have any tips on taking the cluster bulbs out of the little black sockets. This may be a dumb question but I cant seem to get them out. Im going to replace my bulbs because they are getting a little dim.
Old Feb 23, 2004 | 06:46 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
I think u will just have to pull them the large ones ( 3 ) for illumintation are 194 bulbs. They just pull out from what i can remember.
Old Feb 23, 2004 | 06:55 PM
Mires's Avatar
Default Re: (v-attack)
Man these things are stuck in there. I feel like such a dumbass . I cant even change cluster bulbs.
Old Feb 23, 2004 | 06:56 PM
v-attack's Avatar
You did rotate them to the left to get them out right? Just making sure so u dont ruin the circuit board and cluster yo.
Old Feb 23, 2004 | 07:01 PM
Mires's Avatar
Yeah I did that. Thats not what Im asking. When you take them out of the cluster there is a black socket attached to the bulb. I was asking how to get the bulb out of that socket.
Old Feb 23, 2004 | 07:13 PM
markpaco's Avatar
Default Re: (Mires)
You should be able to wiggle it out. The smaller ones (like in the switches) cannot be removed from the base.
Old Feb 23, 2004 | 07:39 PM
Mires's Avatar
Default Re: (markpaco)
Not sure but these things aren't coming out. Oh well, I was just seeing how to change them on my usdm cluster so I could do it on my jdm gauge cluster later. I will try some pliers and see if that helps.
Old Feb 23, 2004 | 07:53 PM
vtec.dc2's Avatar
Default Re: (Mires)
if tis plastic housing around the bulb.. then
try long flat screw driver and rubber hammer (be careful it might brake since plastic) .. few taps should turn it.
Old Feb 23, 2004 | 07:56 PM
Mires's Avatar
Default Re: (vtec.dc2)
Got em! I just couldnt get a good hold on the bulb. I used a shirt and pliers and they came right out. Now I just need to change the ones in my jdm cluster when I get some bulbs. Thanks for all the help guys.
WRTEG
Aug 23, 2004 07:12 PM
The G2 Racer
Jul 18, 2004 04:38 PM
Shaun
Apr 20, 2003 07:26 PM
RHGSR01
Dec 11, 2001 07:46 AM
