I did a h22a swap in my 97 honda accord shoc vtec and need GSR ECU!Need Help
Old Feb 23, 2004 | 04:44 PM
CamGriffin's Avatar
Default I did a h22a swap in my 97 honda accord shoc vtec and need GSR ECU!Need Help
I need help finding at GSR obd 2 ecu. I had a f22 with the ecu and now got an h22 with the old ecu i need a gsr obd2 ecu. I can't find one anywhere can someone please help me find one and a good price.
Old Feb 23, 2004 | 05:14 PM
xxmaxhardcorexx's Avatar
Default Re: I did a h22a swap in my 97 honda accord shoc vtec and need GSR ECU!Need Help (CamGriffin)
that ecu is going to make your car run like ****...if you use it your going to halft to change over your injectors and remove your resistor box... try to convert to obd1
or find an obd2 prelude ecu and by pass the ign safty..
Old Feb 24, 2004 | 04:54 AM
iakona's Avatar
PMed
Old Feb 24, 2004 | 05:11 AM
TOAB's Avatar
why do you need an ecu out of a teg?? wouldnt you be better off getting one for your motor...
Old Feb 24, 2004 | 05:18 AM
jwogen1's Avatar
Default Re: (TOAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmaxhardcorexx &raquo;</TD></TR><TR><TD CLASS="quote">obd2 prelude ecu</TD></TR></TABLE>
from what i hear this might be what you want to try
Old Feb 24, 2004 | 08:14 AM
CamGriffin's Avatar
Default Re: I did a h22a swap in my 97 honda accord shoc vtec and need GSR ECU!Need Help (xxmaxhardcorexx)
So I should just stick and try to find a 97 Honda Prelude SH ecu? Do you know where I can get one and it will just plug in b/c I am obd2 and the ecu for sh is obd2 right? Where can I find one cheap?
Old Feb 25, 2004 | 02:24 PM
accordhybrid's Avatar
I have an SH ECU for sale?
Accordhybrid
Old Feb 25, 2004 | 04:25 PM
CamGriffin's Avatar
Default Re: I did a h22a swap in my 97 honda accord shoc vtec and need GSR ECU!Need Help (accordhybrid)
well i will buy a 97 prelude sh ecu just e-mail me at CamGriffin69@hotmail.com
Old Feb 26, 2004 | 04:45 AM
iakona's Avatar
not going to work unless you get the immobilizer system off the same car. trust me. i've tried.
Old Feb 26, 2004 | 03:37 PM
h22 civ's Avatar
p71 is the teg ecu you think you need. Your car is 97 what year is the motor, if its not OBDII motor you don't want that ecu. Chip a p28 or use the p13. TEG ecu's and h22's don't run very good.
Old Mar 9, 2004 | 05:25 AM
spikefresh's Avatar
Default Re: I did a h22a swap in my 97 honda accord shoc vtec and need GSR ECU!Need Help (h22 civ)
please tell me you have not already bought that ecu. Someone (i believe hasport) makes a conversion specifically for this. One of the SCC mags last year, did an H swap on an either 5th or 6th gen cord. If you go to http://www.sportcompactcarweb.com and search for it, they give you a pretty damn close, step-by-step instructional on how to do the wiring. I have done this swap before, and i found (though using an OBD1) that taking the entire wiring harness apart, and then putting all back together with the added wires, and using the same bulkheads, proved to be alittle more work, but the end result--- my wiring looked better than that of the factory!!!!!
Blake Harvey
Engine Management and Tuning
Nov 15, 2016 01:11 AM
yexer7
Sep 21, 2015 06:27 AM
m6suranski9p
May 14, 2010 10:53 AM
97LXF20B
Nov 1, 2007 09:03 AM
ekfighter
Jul 17, 2004 09:42 PM
