plugging extra O2 sensor bung hole
Old Oct 12, 2001 | 04:07 PM
GruvyTune's Avatar
New User
Default plugging extra O2 sensor bung hole
My fmax kit put a bung hole in the downpipe. Why, i don't know. the stock gsr has it in the cat.
Is there an effective way to plug the hole? Can someone give me specifics on whether i can find a plug or bolt with specific thread size?
Old Oct 12, 2001 | 04:25 PM
Mr. Vapor's Avatar
Default Re: plugging extra O2 sensor bung hole (GruvyTune)
On the Si we have TWO sensors, one in the DP and one in the cat.......i think GSRS are the same
Old Oct 12, 2001 | 04:27 PM
DragII's Avatar
25 Year Member
Default Re: plugging extra O2 sensor bung hole (NYb16)
you put your primary o2 sensor in that hole
the sensor in the hole is the secondary...YOU NEED BOTH
Old Oct 12, 2001 | 04:31 PM
Tomakit's Avatar
Default Re: plugging extra O2 sensor bung hole (DragIIcivic)
obd1 only has a single o2 sensor. is your car obd1 or 2?
Tom
Old Oct 12, 2001 | 04:33 PM
DragII's Avatar
25 Year Member
Default Re: plugging extra O2 sensor bung hole (Tomakit)
if it has one in the cat...it's obdII right? the primary will always have one in the manifold, if there is one in the cat, it would be obdII
right??
Old Oct 12, 2001 | 04:34 PM
GruvyTune's Avatar
New User
95 GSR obd1.
thats why i'm asking.
do you all know the size hole plug i need to look for?
Old Oct 12, 2001 | 04:38 PM
DragII's Avatar
25 Year Member
no sh*t? man, I had no Idea that the GSR does not have an o2 sensor in the manifold....that is wild.
not sure on the size man, you can always bring her down to the store w/ ya
Old Oct 12, 2001 | 05:40 PM
DirtyLude's Avatar
Like I said in the other thread, it'll probably be cheaper for you just to take it to an exhaust shop and get it welded shut. i had to get one of mine welded shut. If they charge you anything, it'll probably be minimal. Any cheesy muffler chain will do.
Old Oct 12, 2001 | 05:49 PM
GruvyTune's Avatar
New User
Default Re: plugging extra O2 sensor bung hole (DirtyLude)
i'd rather not weld it shut. it will be a nice thing to have when i dyno tune it. What's the thread size to look for a bolt to put in there?
Old Oct 12, 2001 | 05:59 PM
DirtyLude's Avatar
If you dyno tune it you'll be putting the wideband O2 sensor up your tailpipe, not screwing it into the downpipe. I'm sure there might be a couple places that will allow you to screw in their lambda sensors, but I've never heard of any.
Old Oct 12, 2001 | 11:31 PM
QuickHonda's Avatar
Maybe its just too late at night and i'm missing something but couldn't he just screw a bolt into the hole. Always use the simplist solution.
Old Oct 13, 2001 | 03:36 AM
GruvyTune's Avatar
New User
Default Re: plugging extra O2 sensor bung hole (QuickHonda)
well, its early morning now and that is probably what I will try to do. I had just thought there were plugs made to fit in these and that someone knew what size to get. I'll bring the pipe to the shop and fit one.
thanks
Old Oct 13, 2001 | 08:15 AM
GruvyTune's Avatar
New User
Got one!!
NAPA sells them.
Old Oct 13, 2001 | 09:06 AM
bigTom's Avatar
u could of just gotten an o2 sensor from somewhere that toiok a ****... cut the wires and leave it hanging
Old Oct 13, 2001 | 08:32 PM
Nfurno's Avatar
Default Re: plugging extra O2 sensor bung hole (ek9t)
Just use a spark plug. It'll fit.
Old Nov 30, 2003 | 08:35 PM
roydogg's Avatar
Default Re: plugging extra O2 sensor bung hole (Nfurno)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nfurno &raquo;</TD></TR><TR><TD CLASS="quote">Just use a spark plug. It'll fit.</TD></TR></TABLE>
Does it really fit? And would it cause any problems?
Old Nov 30, 2003 | 08:52 PM
accordfreak's Avatar
Default Re: plugging extra O2 sensor bung hole (roydogg)
buy a plug from your closest auto store. i found a brass one from kragen auto parts. daymn i forgot what the size though but i know they have it.
Old Nov 30, 2003 | 08:59 PM
JonGP4's Avatar
Default Re: plugging extra O2 sensor bung hole (accordfreak)
it fits, then put a wire and a coil on it connected to a switch, and be fast and furious style with flames out the back
Old Nov 30, 2003 | 09:05 PM
roydogg's Avatar
Default Re: plugging extra O2 sensor bung hole (JonGP4)
I stripped the o2 sensor on my dc 4-1 header and now my dp just has a hole in it with no o2 sensor. I was tuned without a o2 sensor in my dp using a s200. Would it make a difference if I put it on or just plug it shut?
Old Dec 1, 2003 | 01:03 AM
turbopimp's Avatar
OMG... Return of the Living Dead... the bung can be plugged with a 18mm x 1.5 pitch bolt.
Old Dec 1, 2003 | 09:13 AM
roydogg's Avatar
Default Re: plugging extra O2 sensor bung hole (turbopimp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbopimp &raquo;</TD></TR><TR><TD CLASS="quote">OMG... Return of the Living Dead... the bung can be plugged with a 18mm x 1.5 pitch bolt.</TD></TR></TABLE>
lol.....Yeah the search feature really works .
munscher
May 7, 2006 04:11 PM
Wazup
Aug 27, 2005 06:17 PM
Behan
Dec 2, 2003 07:46 PM
integranator
Jul 16, 2003 09:46 PM
