ITR clutch/flywheel
Old Feb 23, 2004 | 10:59 AM
Tommy_Gunns's Avatar
Default ITR clutch/flywheel
Is the ITR clutch/flywheel compatible with all B series motors?
IE. B18B, B16A cable tranny, etc.
Old Feb 23, 2004 | 11:00 AM
Opie's Avatar
Default Re: ITR clutch/flywheel (Tommy_Gunns)
My buddy is running an ITR clutch on his Geezer no probs there
Old Feb 23, 2004 | 11:07 AM
b19coupe's Avatar
I have seen ITR clutch/flywheel combos run in B18B's and B16's with no problems.
Old Feb 23, 2004 | 11:17 AM
RTW DC2R's Avatar
I think the only thing thats diffrent is the number of bolts used to hold the clutch plate on the flywheel. ITR is 9 bolts, others are 6 bolts. Something like that.
Old Feb 23, 2004 | 02:34 PM
Default Re: ITR clutch/flywheel (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">I have seen ITR clutch/flywheel combos run in B18B's and B16's with no problems.</TD></TR></TABLE>
How about ITR clutch/flywheel in a cable tranny B16A?
Old Feb 23, 2004 | 02:51 PM
nfn15037's Avatar
If I remember correctly, cable trannies have a different spline on the input shaft, but the flywheel/PP should work fine. The disk/pp/flywheel will work on any hydro b series.
Old Feb 23, 2004 | 05:15 PM
b19coupe's Avatar
I have only seen ITR clutches in hydro trannies; can't say yeah or nay on cable trannies.
Old Feb 24, 2004 | 06:03 AM
Default Re: ITR clutch/flywheel (nfn15037)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">If I remember correctly, cable trannies have a different spline on the input shaft, but the flywheel/PP should work fine. The disk/pp/flywheel will work on any hydro b series.</TD></TR></TABLE>
Can anyone confirm the disc will not work on a cable tranny B series motor?
Old Feb 24, 2004 | 05:19 PM
B2FiNiTY's Avatar
Will not work on a cable tranny.
98Luder
Oct 8, 2010 09:25 PM
94lsboost
Oct 30, 2003 01:28 AM
SPOON_BeIgHtEeNsEe
Sep 12, 2002 03:33 PM
NVMYSi
Aug 23, 2002 06:30 AM
