how do i get 11.5 compression?
ok, ive been searching and reading all these post and what i get from them is that you cant run forge pistons with out resleeving a h22a block. I DONT WANNA RESLEEVE! so with that said, the highest compression pistons i can use would be the type s piston which puts me at 11. now what else could i do to get to 11.5? mill head? if so, how much? thinner hg, but which one company and how thick? any suggestions or input well help. TIA
This was originally posted by a guy named ranta18
H22 -
Stock JDM = 10.6:1
Stock Type-S = 11:1
Type-S + 0.020 Mill = 11.6:1
Type-S + 0.030 Mill = 11.9:1
Type-S + 0.035 Mill = 12.2:1
2 layer head gasket is about the same as a 0.010 mill."
H22 -
Stock JDM = 10.6:1
Stock Type-S = 11:1
I just happened to find it because I was researching on the pistons and someone happened to post it in that thread. Searching can be a real pia.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by makavelli1227 »</TD></TR><TR><TD CLASS="quote">WHY DONT U WANT TO RESLEEVE...it is better for your engine, it makes it stronger...</TD></TR></TABLE>
PROBEBLY BECAUSE ITS EXPENSIVE. Dont hate
yeah... ive built alot of motors and it gets a bit costly on the sleeves! i do agree with you that its better but cant afford it right now and plus its gonna be a very mild setup. this is my last project so i dont wanna spent ton!
another con to resleeving is the necessity of using aftermarket pistons for the rest of the engines life...unless i have bad info...cant go wrong with oem stuff
just my .02...though sometimes a little skewed
1SIKZ06
Mar 4, 2009 12:59 PM
PSPEC
Apr 22, 2005 07:17 PM
