would these injectors work
Old Feb 23, 2004 | 08:52 AM
KOOL-AID's Avatar
Default would these injectors work difference between flow rating
ok im bout to get my greddy kit and i want to get injectors with it so i find injectors for 54.99 each there accel and it says the flow rating is 44lbs/hr which would be 462cc will my car run to lean if i get these injectors or should i get vortech injectors which are 440cc and the same price just wondering which ones i should get or does it matter how much cc's its spitting between the 462cc and the 440cc thanks oh by the way i have a d16z6 in my ef and i will be running uberdata
Old Feb 23, 2004 | 08:59 AM
WONG FRIED RICE's Avatar
Default Re: would these injectors work difference between flow rating (KOOL-AID)
are you going to be running a upgraded fuel pump too? I'm sure u won't be running lean, in fact u'll probably run rich unless u have it tuned right away. I personally think that the 440's would be good enough. I ran 450's when i ran boost on my y7/y8, and i was running way rich in the beginning before being tuned with hondata.
Old Feb 23, 2004 | 08:00 PM
KOOL-AID's Avatar
Default Re: would these injectors work difference between flow rating (JDMB16ACRX)
yea i am going to upgrade my fuel pump...........im think about just gettting those vortech injectors then but still wondering if there is a being difference and which one would be easier to tune meaning cc's between the two
Old Feb 24, 2004 | 07:54 AM
if i were you i'd go with the 440's that's plenty big. In terms of tuning difficulty they are the same.
HondaKid936
Nov 13, 2008 07:16 AM
russianswty
27
Nov 14, 2006 06:30 PM
LuderCriS
Jul 26, 2005 02:37 AM
KevronsEG
Mar 26, 2002 06:05 PM
GSRrR
Oct 3, 2001 03:18 PM
