FS: 1995 Acura Integra (small accident) with modified 98 B18B1, Nashville TN - $3000
Ok, so I'm in a bind and I need to sell my Integra pretty quick. The car was wrecked back in November, not bad, and is still driveable.. but not perfect none the less. I'll try to get pictures tomorrow since the car is at a friends house right now.
EDIT: Since a couple people have asked: This car was NOT IN AN IMPACT WRECK! I was following a friend down a twisy *** road going a bit too fast and those stupid Michelin XGT-4's gave out and shot me off into a field off a small decline. I hit nothing, just the impact of the drop made the front core support push in a little.. and the rear LCA bent.
1998 B18B1 40,000 miles
LS Head (complete valvetrain)
LS Block (Complete)
LS Transmission (no grinds)
ClutchMasters Stage3 clutch (almost new)
B&M Fuel Pressure Regulator
B&M Fuel Pressure Gauge
NGK Plugs
NGK Wires
JDM DC 4-1 Header (has a tiny crack at the gasket weld, easy fix)
GReddy SP exhaust (busted weld at resonator.. dent in canister, but fixable)
New headgasket
New Oil pump
New water pump
New Timing belt
Panasonic CD Player
Interior is missing some plastic peices, will take pics of that too. Car is also primered grey. The front bumper will need to be replaced and the core support pulled out a tiny bit. Hood still closes though, so its not real bad.
The door needs to be replaced (somone tried to break into it and messed up the weld on the outter door skin) and the rear LCA needs to be replaced.
The car has a clean title, and the car DOES RUN. It just can't be driven without replacing the rear LCA first. But I can do that before the buyer comes if preferred. But I'd suggest towing or transporting it home if you're not in the same local area as me.
I will provide help with shipping if you want to go that route.
I am asking $3000 OBO or may consider trades for a motorcyle for the car how it is (will repair LCA to make it driveable if purchased this week). I think this is a fair price considering a stock LS swap goes for $2200 on hmotorsonline by itself. So you're getting the swap, plus modifications and a car for $800 technically
I have plenty of references on here, and many on ClubSi since I'm a Moderator on CSI.
If you're interested, please contact me the following ways:
AIM - bewSii
Yahoo - sib0o
MSN - bewgsx@hotmail.com
email - sib0o@comcast.net
Modified by bew- at 1:24 AM 2/24/2004
LS Block (Complete)
NGK Plugs
NGK Wires
New headgasket
New Oil pump
New water pump
New Timing belt
Panasonic CD Player
AIM - bewSii
Yahoo - sib0o
This is before the small accident. I am working on getting pics of the car now, but you really wont see the damage other than the cracked front bumper. This was also with the LS wheels, but they were stolen when the car was in the tow lot.
Thanks
If you guys have any questions whatsoever, please ask! As mentioned before, the car does infact run and has a clean title. It's a great project car that just needs some TLC
bew-
May 20, 2004 10:27 AM
