How to check to see if my AC compressor still works??
Old Feb 23, 2004 | 06:25 AM
AndyD's Avatar
Default How to check to see if my AC compressor still works??
Hey guys, I bought my car used about 1.5 years ago. The last owner had all the records for the car. As I was reading through them one said that the mechanic replaced the belts...but used the F22 belt that bypassed the AC compressor. All it said was, "AC inoperable now).
I am curious how I can test it to see if it still works. Is there a quick way to check??
Based on the records....the AC compressor has not been turned for close to 2 years.
Old Feb 23, 2004 | 07:26 AM
Sephro's Avatar
Default Re: How to check to see if my AC compressor still works?? (AndyD)
if the pulley turns by hand then try getting a belt and give it a shot. I bet it won't work right now but might if it gets charged. Did you ever ask the previous owner why they did this? Maybe just for more power...
Old Feb 23, 2004 | 08:02 AM
yellow_jacket's Avatar
Default Re: How to check to see if my AC compressor still works?? (Sephro)
Like he said, check to see if you can turn both the pulley and the clutch by hand. If you can, the system is probably good. Usually the compressor is bypassed because the bearing for the pulley siezes.
For the most part if the compressor is good it shouldn't be a problem to run it again. I've only seen one line explode after a car had not run the air for about 2-3 years. We were just glad the tech wasn't standing over the motor at the time.
Hawaiianhonda
Acura TSX
Apr 16, 2017 11:42 AM
SIR 1.6
Aug 1, 2012 05:23 AM
nickelz34
10
Aug 31, 2009 07:55 PM
