cross drilled rotors > 94 accord wagon
Old Feb 22, 2004 | 02:51 PM
integra dave's Avatar
Default cross drilled rotors > 94 accord wagon
this might sound like a dumb question but i want to change the rotors in the accord and I want to know before i buy >> is replacing the factory rotors with aftermarket rotors the same process as raplacing them with factory rotors? i mean.. then should just fit the same way correct? (i know i have to replace the knuckle and all that btw)
thanks
Old Feb 22, 2004 | 03:25 PM
Mike813's Avatar
Default Re: cross drilled rotors > 94 accord wagon (integra dave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra dave &raquo;</TD></TR><TR><TD CLASS="quote">this might sound like a dumb question but i want to change the rotors in the accord and I want to know before i buy &gt;&gt; is replacing the factory rotors with aftermarket rotors the same process as raplacing them with factory rotors? i mean.. then should just fit the same way correct? (i know i have to replace the knuckle and all that btw)
thanks</TD></TR></TABLE>
from what ive read, alot of peoples cross drilled tend to crack sooner than stock...
and most people use them for autox'ing or high hp cars who really need the stopping power when needed...
most cross drilled are alot bigger than stock and will need bigger rims for proper fitment. if you havent already gotten rims.
& you only need to switch the knuckle if your doing a drum/disc conversion
if im wrong correct me please.
Old Feb 22, 2004 | 05:23 PM
Hondaaccordvtec's Avatar
Default Re: cross drilled rotors > 94 accord wagon (Mike813)
Hey, if you need to replace your rotors, just get Brembo blanks and some good pads. That's all you need.
Old Feb 22, 2004 | 08:44 PM
Import13alla's Avatar
Default Re: cross drilled rotors > 94 accord wagon (Hondaaccordvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaaccordvtec &raquo;</TD></TR><TR><TD CLASS="quote">Hey, if you need to replace your rotors, just get Brembo blanks and some good pads. That's all you need.</TD></TR></TABLE>
-you can get cross drilled or slotted rotors that are stock replacements.
Old Feb 22, 2004 | 08:50 PM
Spider Man's Avatar
Default Re: cross drilled rotors > 94 accord wagon (Import13alla)
cross drilled crack faster?????
Old Feb 22, 2004 | 08:59 PM
basically since i dont do any autocross or even run the car for that matter all i want is the ability to stop faster and better.... just so you know i have 17s on the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import13alla &raquo;</TD></TR><TR><TD CLASS="quote">
-you can get cross drilled or slotted rotors that are stock replacements.</TD></TR></TABLE>
are they stock though? like from the dealer? or are they aftermarket rotors?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import13alla &raquo;</TD></TR><TR><TD CLASS="quote">Hey, if you need to replace your rotors, just get Brembo blanks and some good pads. That's all you need.</TD></TR></TABLE>
those brembo blanks..... do they come in slotted?
Old Feb 22, 2004 | 09:10 PM
they are aftermarket. try powerslot.com? also brembo makes some crossdrilled rotors that are a stock replacement too. guessing brembo.com?
Old Feb 22, 2004 | 09:13 PM
honestly the blanks are half the price, and the crossdrilled rotors are really unnecessary. they do look kinda cool though.
Old Feb 23, 2004 | 12:17 AM
2000Accord5sp's Avatar
I believe (speak up if you have any other experience) that the cross drilled rotors that crack are either cheap knock off rotors or ones done by people themselves. I haven't heard of any brembo cross drilled rotors cracking.
But if you get bigger rotors, remember that you'll need different calipers also...many things will need to be replaced besides just the rotor at that point.
OldMrAccord
Nov 20, 2006 03:26 AM
Defcon2030
Dec 21, 2005 07:42 PM
pumafeet10
Aug 19, 2004 07:00 AM
integra dave
Feb 22, 2004 09:06 PM
Conechaser
Jun 30, 2001 03:41 AM
