safe to buy used clutch?
Old Oct 12, 2001 | 09:06 AM
guyuenvy's Avatar
Default safe to buy used clutch?
hi someone is selling a used clutch he said used 500 miles for cheap. Is it safe or should i just buy a new one?
Old Oct 12, 2001 | 09:09 AM
b18bturbo's Avatar
Default Re: safe to buy used clutch? (guyuenvy)
you gotta inspect it you really better off buying a newone though. 500 miles you dont know what they did with it, They could have glazed it heated up destroyed it anything possible
Old Oct 12, 2001 | 09:10 AM
rtype11's Avatar
Maybe he learnt to drive stick in 500 miles, now he needs a new one.
get pics of the surfaces, make sure there is a return policy if its junk.
I would spend the extra on a new one.
Old Oct 12, 2001 | 10:46 AM
Rain_man's Avatar
New User
Default Re: safe to buy used clutch? (rtype11)
Clutches, brake pads, rotors, condoms... there are somethings that really shouldn't be bought used.
If you are doing the install yourself, then consider it IF it's cheap enough. Like 100 dollars. You can always replace it yourself if it prematurely goes bad...
Otherwise, if you are paying for the install, it would suck to install it and then find out it goes out in a few hundred miles and then pay for another install again.
Old Oct 12, 2001 | 10:58 AM
redline's Avatar
Default Re: safe to buy used clutch? (Ein)
**** got beat to the punch line
Old Oct 12, 2001 | 11:12 AM
bigTom's Avatar
Default Re: safe to buy used clutch? (redline)
i like what someone said on this board a little while ago about used clutches... i forgot who it was though... but buying used clutches is like buying used underwear... u never know what ur getting into
Old Oct 12, 2001 | 11:47 AM
TurboInteg95's Avatar
I would just buy a new one, better safe then sorry.
accord99power
Transmission & Drivetrain
May 20, 2009 07:22 AM
UberJDMef8
Aug 26, 2005 05:45 AM
PatrickGSR94
Apr 16, 2003 09:40 AM
type Gendy
Nov 1, 2002 05:58 PM
Snafu-Si
May 30, 2002 11:36 PM
