search didn't help. 88 Crx si won't rev pass 3k. throwing a code4. pls help!
Old Feb 22, 2004 | 11:19 AM
South Bay Surfer's Avatar
From: South Bay, Torrance/Carson, CA, United States
Default search didn't help. 88 Crx si won't rev pass 3k. throwing a code4. pls help!
i checked my helms guide and it says crank angle sensor. anyone here ever encountered a code 4. i suspect the problem is distributor related. pls. help!
Old Feb 22, 2004 | 12:05 PM
Default Re: search didn't help. 88 Crx si won't rev pass 3k. throwing a code4. pls help! (iluvjasmine)
Old Feb 22, 2004 | 04:42 PM
Old Feb 22, 2004 | 04:46 PM
Xgen's Avatar
this may sound dumb, but do you have your cam angle sensor plugged in? and also what motor you have?
Old Feb 22, 2004 | 05:00 PM
Default Re: search didn't help. 88 Crx si won't rev pass 3k. throwing a code4. pls help! (honda_guy_83)
yah, everything is plugged in. and the motor is the stock d16a6.
Old Feb 22, 2004 | 05:01 PM
CRX-RX's Avatar
Checked your timing with a timing gun? Your belt could be off a tooth or more. I would start there, then if all is ok and your belt is aligned correctl check out the distributor.
Old Feb 22, 2004 | 05:08 PM
1point5CRX's Avatar
Default Re: search didn't help. 88 Crx si won't rev pass 3k. throwing a code4. pls help! (CRX-RX)
i literally just gto done with my mpfi zc swap (91 crx dx) and i had a code 4.with mine,its diffrent, my pins on the ecu weren't swapped correctly another problem was code 10,2 plugs were reversed and my timing was retarded 1 tooth, its all fixed, me and boostedb20vtec got all the bugs worked out except for the tps but it still runs pretty good.
Old Feb 23, 2004 | 10:01 AM
Default Re: search didn't help. 88 Crx si won't rev pass 3k. throwing a code4. pls help! (1point5CRX)
anyone else
xiona
Sep 1, 2007 09:15 PM
xiona
Aug 31, 2007 02:09 PM
Iron_Forrix
May 4, 2007 12:14 PM
Ch3mik
Jul 19, 2005 04:41 PM
nayrone
Nov 2, 2004 08:18 AM
