Tranny keeps loosing OIL
Old Feb 22, 2004 | 08:09 AM
revv's Avatar
Default Tranny keeps loosing OIL
I've done everything. I've changed all the plugs "drain and fill" also changed the the rubbers that go in the tranny hole where the safts plugs in "forgot the proper name" i also eve chaged my passenger side drive shaft thinking it may help. oil is only on the passenger side,
i'm still loosing oil and no aparent cracks anywhere. stupid 5th gear pops out when i run low. driving me nuts.
Cable trany is a Y1 LSD
Your help i much appreciated
Old Feb 22, 2004 | 08:13 AM
sleeperek's Avatar
Default Re: Tranny keeps loosing OIL (revv)
It is called tranny seals....Did you change out both of them? There is one on the driver side and the other is on the passenger side....Also be very careful when installing these...the slightest dent on any of these seals will result in a leak...I would recommend you to clean off the oil and drive it around the block and check it again to see where its comin from...
Old Feb 22, 2004 | 10:40 AM
Boost2NA's Avatar
Default Re: Tranny keeps loosing OIL (sleeperek)
my vote goes to check your axle seals. Seal that seperates the axle from tranny.
Old Feb 22, 2004 | 03:37 PM
revv's Avatar
i change the seals and even yesterday i changed the driveshaft. no apparent cracks anywhere.
Old Feb 22, 2004 | 05:45 PM
everidge4's Avatar
Default Re: (revv)
Is the tranny losing all the oil? If you have to much oil it can leak until it is at the proper level.
sk8board{Pete}
Jul 31, 2008 07:59 PM
HondaHeddie
Sep 29, 2006 07:40 PM
revv
Feb 22, 2004 03:37 PM
serious
Apr 3, 2003 06:46 PM
