Cleaning ITR seats?
Old Feb 22, 2004 | 12:59 AM
NINE TRE's Avatar
Default Cleaning ITR seats?
sup guys,
thought i'd post here...
anyone know the best way(s) to clean the ITR seats? (both the back and bottom fabrics + suede) i recently purchased 2 fronts for my ride, and i want to get some stains out (of the fabric part) before i put 'em in...
sorry, i know pics would help to view the condition its in...but can't do right now..
but anyone is familiar or have done this before, it would help man...
thanks
Old Feb 22, 2004 | 01:06 AM
^jefs0ng's Avatar
Banned
Isn't there a specific cleaner for suede? I remember reading about something like this and there was like 1 specific product some people used..
Old Feb 22, 2004 | 01:21 AM
TheGSRGuy's Avatar
Default Re: (#jefs0ng)
Most shoe stores carry suede cleaning products. There are special brushes. For cleaning, there is an actual stone that works wonders on removing scuffs and minor stains.
Old Feb 22, 2004 | 01:55 AM
NINE TRE's Avatar
Default Re: (TheGSRGuy)
i see, yea i think i can find something to clean the suede, but the actual seat(where i sit on) has like a stain from spilling a coke or juice of some sort, and it left the mark, so i was once told to really becareful on what i use to clean that, or i might make this stain get worse...
i thought of steam cleaning it?
Old Feb 22, 2004 | 04:13 AM
Pondus's Avatar
Default Re: (drunkn_tyger)
Try that foaming spray stuff for cleaning furniture, spray on and let it foam up and wait a few minutes before wiping off with a moist towel.
Old Feb 22, 2004 | 04:56 AM
sqwerz
Guest
Posts: n/a
For the seude part of the seat go to payless and buy the seude cleaner.For the part where you sit on use a mild soapy solution diluted well in water, use a cloth and just clean lightly...worked well for me and never had a problem with discoloration or wear
Old Feb 22, 2004 | 06:38 AM
six_speed's Avatar
upholstery cleaner...pepboys/auto zone/kragen.
Old Feb 22, 2004 | 07:21 AM
bubbakush's Avatar
Default Re: (Humping_dragon)
This is the advice i was givin from autopia yesturday
"Now, as far as the seats, the inside is a nylon mesh and the outside is alcantara. What I would do with those is use a woolite water mixture of 8 parts water, 1 part Woolite in a spray bottle. Spray it on a terry towel and work it into the fabrics.
HOWEVER, I could be wrong. I have never worked on alcantara before. It is a delicate material to clean. Wait for some more insight on the alcantara cleaning before you go at it, but as far as the floor mats and carpeting, I have had great success with the directions above."
I personally had dust on the alcantara part and I used a damp terry/cotton towel and gently cleaned up the dust; worked excellent to clean them up. As far as the nylon mesh in the middle i used the woolite mixture for a small stain and it cleaned up really nice.
Check out this site too
http://www.alcantara.it/istitu...e.pdf
There are specific products you can buy to clean it as well. Hoped this helped a bit. Good luck
Modified by bubbakush at 4:32 PM 2/22/2004
Old Feb 22, 2004 | 07:29 AM
kepani's Avatar
Default Re: (bubbakush)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubbakush &raquo;</TD></TR><TR><TD CLASS="quote">"Now, as far as the seats, the inside is a nylon mesh and the outside is alcantara. What I would do with those is use a woolite water mixture of 8 parts water, 1 part Woolite in a spray bottle. Spray it on a terry towel and work it into the fabrics.</TD></TR></TABLE>
exactly right. woolite is a gentle detergent and will not harm the alcantara fabric. the fabric on the itr seats is NOT suede. do not used suede type cleaners! i might add that after you've worked the detergent into the seat, repeat the same process with a towel with just water (damp of course). keep rewiping untill the detergent has been pulled out of the fabric. let dry and then you can install.
Old Feb 22, 2004 | 07:34 AM
bubbakush's Avatar
Default Re: (kepani)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kepani &raquo;</TD></TR><TR><TD CLASS="quote">
exactly right. woolite is a gentle detergent and will not harm the alcantara fabric. the fabric on the itr seats is NOT suede. do not used suede type cleaners! i might add that after you've worked the detergent into the seat, repeat the same process with a towel with just water (damp of course). keep rewiping untill the detergent has been pulled out of the fabric. let dry and then you can install. </TD></TR></TABLE>
Aye when extracting the soap and water out of the nylon mesh i had wet/dry vac to get it to rise to the surface then blotted it with a towel; you would be suprised how much water i got out and then i just left it dry overnight. With the alcantara i dotn knwo if i would use the vac, just wipe it like kepani said since its so delicate material
Modified by bubbakush at 4:48 PM 2/22/2004
Old Feb 22, 2004 | 09:33 AM
NINE TRE's Avatar
cool guys, thanks... i will definitely try this out...
the product is called "Woolite"? can i find this at any wal-mart or is there a specific store for this kind of product...?
thanks again
Old Feb 22, 2004 | 09:41 AM
onyx00's Avatar
I've used the woolite / water combination and it worked great.
Old Feb 22, 2004 | 09:59 AM
py1188's Avatar
Default Re: (onyx00)
Woolite has worked for the cloth, and just water for the alcantra, fake suede. I have yet t use a real suede cleaner but would opt against since the material isn''t actualy suede.
That alcantra site provides a lot of good info as well
Old Feb 22, 2004 | 12:57 PM
bubbakush's Avatar
Default Re: (py1188)
woolite is just a regular cleaner you should be able to pick up at your local supermart or wal-mart
Old Feb 23, 2004 | 06:11 AM
NINE TRE's Avatar
cool... picked it up today... will work on this thanks guys
Old Feb 23, 2004 | 09:58 AM
egvx2001's Avatar
whoops im a dork i guess its not suede
wool,ite
Modified by egvx2001 at 8:59 AM 2/24/2004
B_Swapped93
May 10, 2013 12:07 PM
is3oo
Sep 23, 2003 06:59 PM
singlecam screamer
Aug 2, 2002 08:54 PM
311
Jul 5, 2002 11:12 AM
hybrid_eg
Aug 21, 2001 11:45 AM
