I want to do fuel cutoff where is the best most convieient place to tap pump power
Old Feb 21, 2004 | 10:05 PM
luder22's Avatar
Default I want to do fuel cutoff where is the best most convieient place to tap pump power
basically the title says it all i have a 95 Prelude and I am about to do a silly audio install besides the mostly bolt on performance stuff I can see the car as a HoTT target so im natrally worried
Old Feb 22, 2004 | 03:32 PM
GAtegs's Avatar
Default Re: I want to do fuel cutoff where is the best most convieient place to tap pump power (luder22)
Mmmm, lets discuss it online here so a thief can come and read it and steal out cars because they know exactly where thefuel cutoff switch is.
Old Feb 22, 2004 | 11:48 PM
vteg's Avatar
New User
Default Re: I want to do fuel cutoff where is the best most convieient place to tap pump power (a98tegLS)
Purchase a helms manual, or pull off your back seat and start there. Get the wire color and look for it in a harness going to the rear.
Old Feb 23, 2004 | 10:48 AM
luder22's Avatar
Default Re: I want to do fuel cutoff where is the best most convieient place to tap pump power (vteg)
I have a Honda Service manual for my year Vtec Prelude Its Black and pretty thick maybe 1000 pages so i guess i should be able to find it inside. I plan on using 2 40A relays Do you have any idea the current draw for a fuel pump ? thanks for asll the help so far
Old Feb 23, 2004 | 10:50 AM
luder22's Avatar
a98tegLS you dont have a clue to what we are even talking about . The whole point is to hide the momentary switch so no one should be able to even imagine where it is or even that it exists But thanks for playin
Old Feb 24, 2004 | 12:40 AM
vteg's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luder22 &raquo;</TD></TR><TR><TD CLASS="quote">Do you have any idea the current draw for a fuel pump ? thanks for asll the help so far </TD></TR></TABLE>
I have seen the current usage map for the walbro gss342. It was between 10-17 amps depending on pressure and flow. That pump supports 500 hp. So I think your relays should be safe on the stock pump.
sivik_outkast
Oct 18, 2008 06:49 PM
CivicSiDude18
Nov 6, 2007 08:10 AM
EJ8 GSR-T
Audio / Security / Video
Dec 25, 2006 06:46 PM
Elemental
Jul 28, 2004 11:07 PM
VXpride
11
Mar 11, 2002 07:13 PM
