89 Honda civic dx installation of a B series Question!
Old Feb 21, 2004 | 07:13 PM
BravoTwoZero's Avatar
Default 89 Honda civic dx installation of a B series Question!
Im looking at buying a motor from this website...
http://www.hmotorsonline.com/s...gines
Would item # 30003 ( the B16a 92-93 integra (XSi) ) fit into the 89 civic dx easily with the hasport motor mounts?
Would I be able to "tell" a big difference buying the LSD tranny and is it worth $400 extra?
Other than 10hp, 2 torque and 0.2 compression, what is the difference between item # 30003 and item # 30002 and would item # 30002 be a better buy.
Old Feb 21, 2004 | 09:19 PM
tree's Avatar
Default Re: 89 Honda civic dx installation of a B series Question! (BravoTwoZero)
go with 1 or 2. the third is obd-1
more trouble. But you can find a b16 out of an sir (No obd bullshit) with an lsd, and i highly recommend it
Old Feb 21, 2004 | 10:50 PM
T S R Performance's Avatar
Default Re: 89 Honda civic dx installation of a B series Question! (moms-wolf)
converting to obd-1 SUCKS. get the Si-R with LSD, and yes its worth it if you have a built motor
Old Feb 22, 2004 | 11:20 AM
Default Re: 89 Honda civic dx installation of a B series Question! (CivicHatchSOHC)
What do you mean "if you have a built motor"? Do i need to build the motor up ?
Old Feb 22, 2004 | 11:23 AM
ghettocrxsi's Avatar
COnverting to obd 1 is easy. YOu can buy a jumper harness for like 120 dollars from jason on this board.
And all you need is a 4 wire o2 sensor and obd1 computer and distributor.
But you get all the with your obd1 swap. sir2 motors have a better intake manifold and head flows more and does not have that cast crap and those junk old school cams like the first gen obd 0 motors.
Old Feb 22, 2004 | 12:02 PM
Jays91DXhatch's Avatar
Default Re: 89 Honda civic dx installation of a B series Question! (ghettocrxsi)
See, I just noticed last week I was given a Xsi motor with the YS1 tranny. Other then having to buy a new clutch disk since I had bought one for the 90-91 already (Xsi is from 92-93) I thought that was the only difference. Then I looked at this topic and noticed the Xsi has 170hp. :D
It does say JDM OBD1 on that website, but it still used the PR3 ECU. And it's still 2 1-wire O2 sensors not a 4-wire O2 sensor like on the OBD-1 stuff. And the distributor I got on there is a white plug. Also there was the plug for the resister box which I don't think would be used with a regular OBD1 ECU.
can anyone confirm this? Is it that in the 92-93 JDM integra they kept OBD-0??
clkupai
Feb 2, 2013 06:42 AM
Diiplomat
Sep 10, 2012 10:00 PM
Tuner85
17
Apr 6, 2007 10:57 PM
davidcrx89
Feb 19, 2005 09:54 AM
runitup
Nov 30, 2002 07:53 PM
