Hondata Have I Got It Right?
Well I am looking into getting hondata and I have search the topics and I think I know what Im doing I would just like to make sure??
I need for my JDM B18c Spec R :
OBD-2 ----> OBD-1 Conversion Harness
OR
OBD-2 Ver2 -----> OBD-1 Conversion Harness
Could You please tell me which one??
P28 ECU - Wont this stuff up where my VTEC Engages and fuel maps Etc..
Also what P28 ECU do you guys recommend for this spec engine?
Hondata S200 Program
Do I need anything else with Hondata. I am not going to be boosting I will stay N/A so I wont need the boost program and self tune programs etc...
Is that all I need. And when I put hondata in with a p28 ecu wont all my fuel maps vtec engagement etc... Be changed to that ecu?? I will have to get it tuned straight away to run correctly correct???
Is there anything else I need to know?? Also thinking of getting Hondata IM Gasket.
These are serious questions I have search and would really appreciate help.
Thankyou
OR
Thankyou
you need the sensor/solonoid from a usdm b series engine. your crossover is controlled via the ecu alone. the us versions have a pressure sensor and whatnot. you will need to covert that over as well as get the rat-tail for the obd2 to 1 coversion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redGSRguy »</TD></TR><TR><TD CLASS="quote">Somewhat on topic, if your going to stay all motor is the s100 sufficent?</TD></TR></TABLE>
just get the s200 its good **** and worth the money
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snail »</TD></TR><TR><TD CLASS="quote">you need the sensor/solonoid from a usdm b series engine. your crossover is controlled via the ecu alone. the us versions have a pressure sensor and whatnot. you will need to covert that over as well as get the rat-tail for the obd2 to 1 coversion</TD></TR></TABLE>
With Hondata you can skip the non-existant sensor checks.
http://www.hondata.com/romeditorv3.html
