DRAG III TURBO KIT OWNERS
Old Oct 11, 2001 | 11:06 PM
Leimokei's Avatar
New User
Default DRAG III TURBO KIT OWNERS
i've heard of the turbo manifold cracking, after a while. Doesn't seem to be able to handle the load...have any of you guys had this happen to you? any suggestions on a different manifold capable of not cracking...i think its made of cast iron but not 100% sure....
Old Oct 11, 2001 | 11:38 PM
Anthony K's Avatar
New User
Default Re: DRAG III TURBO KIT OWNERS (Leimokei)
well, i'm awaiting my drag kit which should arrive tomorrow afternoon. Anyways, I think the manifold cracks because 1) It's kinda thin, and 2) when you connect it to your exhaust system, the manifold receives plenty of stress. I think to solve the problem, you need to use some flexpipe to join the downpipe to your exhaust so that the stress can be relieved. I heard this a while back so it might not be entirely accurate.
Old Oct 11, 2001 | 11:42 PM
ken's Avatar
ken
Default Re: DRAG III TURBO KIT OWNERS (Anthony K.)
I've heard that it can also be from all the heat wearing out the welds or something. I was planning on having my manifold, turbo, and dp all thermal coated before it goes on.
Old Oct 12, 2001 | 12:02 AM
Leimokei's Avatar
New User
Default Re: DRAG III TURBO KIT OWNERS (SeaDawg)
how would the thermal coat run?
Old Oct 12, 2001 | 12:51 AM
BoostinDC2's Avatar
they crack. but im on my third one and this one has lasted me awhile
Old Oct 12, 2001 | 09:05 AM
Ri5e's Avatar
Default Re: DRAG III TURBO KIT OWNERS (BoostinDC2)
They will crack if you modify them in anyway, spray water on it when it's burning hot, from dragging it alot, or if you wrap them up with something that keeps the heat in (which also keeps moisture in = bad).
Old Oct 12, 2001 | 09:18 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: DRAG III TURBO KIT OWNERS (BG Boost)
Mine cracked on it`s 3rd year. I picked up a Rev hard for 300. I wouldn`t lose any sleep over it. Worry about the wastegate.
Ryan
Old Oct 12, 2001 | 01:16 PM
hybrid_eg's Avatar
Default Re: DRAG III TURBO KIT OWNERS (vtecvoodoo)
plus when you buy drag kit it has liftime warnatee on the manifold so if it does fok up you get it replaced.. dont quote me on this but thats the last i've heard i think!
i'm gonna start of with a small kit for the first year then when i have the cash to rebuild move on to a customs set up or something like drag/rev hard just slightly modified.
Old Oct 12, 2001 | 02:52 PM
Prelussion's Avatar
BG what are your times and what is your setup?
Old Oct 12, 2001 | 03:39 PM
Flamenco-T's Avatar
Default Re: DRAG III TURBO KIT OWNERS (Prelussion)
buy the manifold from importparts next time, they do covered the manifold under warranty.
do a search for "drag manifold" on forced induction, you'll see ben@importparts thread on the warranty on the manifold.
stan
egVTI
Dec 19, 2005 08:24 AM
PnX-R
May 7, 2004 02:28 PM
TurboTeG4
Jul 6, 2003 08:48 PM
DocF
Jul 16, 2001 12:46 AM
