Cam gears or Pulley's
Old Oct 11, 2001 | 11:00 PM
SoCal ITR's Avatar
Default Cam gears or Pulley's
How much gain in HP/ which would give more power? how long does it take to install each? Are either worth it on a stock engine?
Old Oct 12, 2001 | 08:46 AM
yakkosmurf's Avatar
Default Re: Cam gears or Pulley's (SoCal ITR)
They are two different animals. Pulleys are easy to install and bolt on, but give next to no power. Cam gears can give very nice gains, but you have to tune them on a dyno. Pulleys might get you 2 HP while gears can add 5-10 HP from your stock cams if you tune the car right. It's up to you. I think pulleys are a waste of money, and I own a set.
Old Oct 13, 2001 | 03:15 AM
SoCal ITR's Avatar
Default Re: Cam gears or Pulley's (yakkosmurf)
How long does it take to install cam gears? How much are they, and could I do it myself? What would the final cost for cam gears be? As far as Pulley's, How long do they take to install, just out of curiosity.... Thanks!
Old Oct 13, 2001 | 06:10 AM
Its_real&its_spectacular's Avatar
New User
If you're comfortable doing something like a timing belt, you could do a set of gears. However, you'd need time on a Dyno with someone who knew what to do with one of those animals...
Old Oct 13, 2001 | 05:44 PM
SoCal ITR's Avatar
Default Re: Cam gears or Pulley's (Its_real&its_spectacular)
Thanks for the info
Old Oct 13, 2001 | 05:51 PM
zentraedityper's Avatar
i have aem power pulleys they are not worth it..i think i got only 1-2 hp...i would go for the cam gears for sure and a vafc to tune everything right...you will get a good amount of horsepower from the cam gears....
Old Oct 13, 2001 | 10:24 PM
SoCal ITR's Avatar
Default Re: Cam gears or Pulley's (zentraedityper)
Do I need a VAFC to tune it or can they do that without one?
Old Oct 13, 2001 | 10:34 PM
yakkosmurf's Avatar
You don't need a V-AFC to tune a set of cam gears. Having one will give you more power of course, but you don't have to have ont to get power out of cam gears.
Old Oct 15, 2001 | 01:11 AM
SoCal ITR's Avatar
What exactly is a V-AFC?
Old Oct 15, 2001 | 04:50 AM
yakkosmurf's Avatar
Apex-i makes one. It will adjust your VTEC crossover as well as your air fuel ratio. This helps your engine to run at it's maximum potential with the given parts you have.
Old Oct 15, 2001 | 04:48 PM
SoCal ITR's Avatar
Will a V-AFC give me power by itself?
Old Oct 15, 2001 | 09:30 PM
SleepyR's Avatar
New User
would cam gears void your warranty? don't you have to cut the valve cover to access them?
Old Oct 16, 2001 | 07:29 AM
Dirty GS-R's Avatar
New User
Default Re: Cam gears or Pulley's (SleepyR)
Cutting the valve cover will allow you to access the cam gears much easier for tuning but you don't need to do that. By not doing that you just have to take the valve cover off everytime you need to tune the cam gears.
2kdrift
Mar 15, 2016 02:32 PM
Ek4 life
Nov 29, 2007 08:06 AM
raysjdmh22a
Sep 4, 2005 07:07 AM
NVBAM
May 21, 2003 09:00 AM
Stewie
Sep 3, 2002 06:30 AM
