b16a swap ?
Old Feb 21, 2004 | 08:06 AM
jdm420da6's Avatar
Default b16a swap ?
ok im swapping an OBD2 b16 into a 89 EF. ive got everything i need to do the swap however i need to know what i need to do as far as wiring goes. i have the 90 Si harness and i heard i could use that along with a jdm distributer which i have, but i also heard there will be some other issues too. wondering if anyone could help.
also im going to need a vtec fuel pump huh?
Old Feb 21, 2004 | 09:15 AM
ScottEK's Avatar
Default Re: b16a swap ? (jdm420da6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm420da6 &raquo;</TD></TR><TR><TD CLASS="quote">ok im swapping an OBD2 b16 into a 89 EF. ive got everything i need to do the swap however i need to know what i need to do as far as wiring goes. i have the 90 Si harness and i heard i could use that along with a jdm distributer which i have, but i also heard there will be some other issues too. wondering if anyone could help.
also im going to need a vtec fuel pump huh?</TD></TR></TABLE>
You should check out the hybrid forum.
Have you decided what your converting yet? You are either going to have to convert the engine to OBD0 or convert the car to OBD2. You have a lot more ahead of you than you think, it's not just an issue of what distributor you use.
94DCTeg
Oct 30, 2020 10:46 PM
ultm8mind
Northeast
Feb 6, 2011 12:51 AM
juanhda9
Dec 24, 2010 02:03 PM
DOHC Vtec TSIT
Apr 11, 2006 06:03 AM
jdm420da6
Feb 25, 2004 04:02 AM
