what would i need for the Toda SPEC B head package??
Old Feb 20, 2004 | 11:02 PM
Stryker's Avatar
Default what would i need for the Toda SPEC B head package??
i know that i need cams, came gears, valves and retainers from TODA.... but do i need to upgrade my ECU nad tune my car with a vafc???
oh yeah my car is a 2000 integra Gs-R
Old Feb 21, 2004 | 10:58 PM
Stryker's Avatar
Default Re: what would i need for the Toda SPEC B head package?? (Stryker)
bump! anyone know??
Old Feb 22, 2004 | 08:12 AM
Stryker's Avatar
TTT
Old Feb 22, 2004 | 08:17 AM
Kendall's Avatar
I wouldn't recommend a VAFC, but tuning is recommended. See if Toda offers an ECU reflash, or get Hondata. I'd also recommend upgrading the intake manifold, header and exhaust if you haven't already. Also, do you plan on running stock compression?
Old Feb 22, 2004 | 09:02 AM
Stryker's Avatar
Default Re: (Kendall)
yea i do plan on running stock compression
Old Feb 22, 2004 | 09:14 AM
Kendall's Avatar
At the very least, I'd go to a thinner headgasket to bump up the compression a bit. You'll get more out of the cams that way.
Old Feb 22, 2004 | 09:26 AM
IN VTEC's Avatar
Injectors. Preferrably '97+ Prelude or S2000 injectors.
It's preferrable to also get a chipped ECU or Hondata so you don't max out the injectors so quickly, correct for the injectors better than a VAFC can, and for a higher rev limiter. Either way, you want to be able to reburn or burn changes to custom tailor the base maps and other ECU functions for the cams. It will also obviate the VAFC.
Old Feb 22, 2004 | 05:14 PM
Stryker's Avatar
thanks for the help guys
pornstar4777
Nov 20, 2005 12:28 PM
itr501
Apr 24, 2002 10:00 PM
nsx-Animal
Apr 13, 2002 06:38 AM
tecnic1
Feb 4, 2002 08:46 AM
