How to tell if a FF car has LSD or not?
Old Oct 11, 2001 | 08:19 PM
Mugen_R's Avatar
New User
Default How to tell if a FF car has LSD or not?
Hi all,
I was wondering if you could tell if a car has been equipped with an LSD or not. If so, how? you gotta jack the car up right? spin 1 wheel or something?!?
Thanks
Old Oct 11, 2001 | 09:04 PM
EPGONZALEZ's Avatar
Default Re: How to tell if a FF car has LSD or not? (Mugen_R)
yeah when your spin one wheel the other should turn the same direction..it it goes the opposite..no lsd
Old Oct 11, 2001 | 09:22 PM
sgT's Avatar
sgT
Default Re: How to tell if a FF car has LSD or not? (EPGONZALEZ)
not true.
the stock ITR diff will spin the wheel in the opposite direction like an open
diff because its unlocked while unloaded.
The only real way to tell is to drive around a turn and apply power on exit.
Old Oct 11, 2001 | 09:26 PM
yellow blur's Avatar
Default Re: How to tell if a FF car has LSD or not? (sgT)
sgt, can you riddle me this?
while using my stock jack to rotate my rear tires to the front, i noticed that before i took them off to switch i was able to rotate my wheel backwards, my front wheels specifically, and it was making a very odd clicking noise. does that have anything to do with the differential? i ask this because when i take turns from a stop sign sometimes i noticed a lot of slipping coming from the tires, isn't the lsd supposed to address the slipping?
Old Oct 11, 2001 | 09:30 PM
sgT's Avatar
sgT
Default Re: How to tell if a FF car has LSD or not? (yellow blur)
I would have to hear it.
But i would see if i could locate where the clicking was coming from. eg cv, diff area, bellhousing.. etc
Old Oct 11, 2001 | 09:49 PM
Mugen_R's Avatar
New User
sgT,
I tried that in the rain yesterday, and normally cars without LSD would go straight when you have your foot on the gas pedal. But it actually wanted to turn. I did it a few times and same thing. So I was wondering if there is any other way to test it to see if it does or not, rather than pulling out the whole complete gearbox.
Old Oct 11, 2001 | 10:05 PM
sgT's Avatar
sgT
Well, if you put your foot on the gas and the revs dont shoot up and rather the
car tries to turn, then you have good tires. 1 of 3 things will happen in your
situation:
1. both tires will spin sending you straight
2. inside tire will start to spin making rpms shoot up and you slow down
3. both tires grab and you turn
1 and 3 indicate LSD USUALLY, 2 is definitely open diff.
Old Oct 11, 2001 | 10:13 PM
how would a torsen type differential operate?
[Modified by yellow blur, 11:13 PM 10/11/2001]
Old Oct 12, 2001 | 12:24 AM
EPGONZALEZ's Avatar
i am a misimformed idiot...playing too much with V8's lately
Old Oct 12, 2001 | 01:04 AM
DutchITR1689's Avatar
If the front wheels have LSD they would feel higher than rear wheels, right?
Old Oct 12, 2001 | 04:07 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
if you were to pull one axle and look through the diff, if you can see the other axle with no obstruction, you have a lsd. if there is a metal bar, kinda looks like a pin, obstructing your view of the other axle, it's an open diff.
Old Oct 12, 2001 | 04:23 AM
sgT's Avatar
sgT
Default Re: How to tell if a FF car has LSD or not? (MiGs)
That is just torque steer.
That could happen with or without an lsd.
Old Oct 12, 2001 | 08:11 AM
Scorpaznatica's Avatar
New User
Hi all,
Thanks
It drives like an FR
Old Oct 12, 2001 | 08:28 AM
sgT's Avatar
sgT
Default Re: How to tell if a FF car has LSD or not? (EKnine)
I wish.....
jdmsleeper12
Transmission & Drivetrain
13
Jan 21, 2010 04:58 PM
93Ludevtech
Dec 15, 2005 06:20 PM
daddymaxx
40
Feb 9, 2004 04:43 PM
itr1236
Feb 4, 2004 07:26 PM
Rain_man
Jan 30, 2003 09:52 PM
