i just discovered an oil leak :(
Old Feb 20, 2004 | 06:55 PM
pete332's Avatar
Default i just discovered an oil leak :(
ive had the R in storage for about two months now, and in the past couple days, i noticed it has started to leak oil.... anyway, i traced it back up to the filter, but the filter is on tight. is it possible that it is on too tight? jw what the problem might be. thanks.
Old Feb 20, 2004 | 08:02 PM
B2FiNiTY's Avatar
Default Re: i just discovered an oil leak :( (py01-0332)
Do you have any aftermarket internals? First thing to check is the valve cover gasket.
Old Feb 20, 2004 | 08:09 PM
pete332's Avatar
Default Re: i just discovered an oil leak :( (B2FiNiTY)
cam gears, but thats about it....
Old Feb 20, 2004 | 08:48 PM
blykins's Avatar
Banned
There's a gasket that goes b/t the block and the oil cooler. See if that may be it.
Old Feb 20, 2004 | 08:56 PM
B2FiNiTY's Avatar
Check the cam gear seal. I along with others such as Trey have also had this problem. It was horrendously annoying.
Just pop open the valve cover and take off the gears. It might be that one of the seals slid out.
My leak was coming from the oil pan, a/c area. Only on that side. It then spread everywhere.
Looked like a headgasket leak.
Old Feb 20, 2004 | 09:26 PM
Utilitarian's Avatar
I feel you man. I had a 97 Prelude and changed my own oil religiously. Anyway, when I went to sell it, a potential buyer paid almost $100 dollars to get it "pre inspected" and one of the shortcomings was an oil leak at the filter. They said the filter wasn't tightened enough. Good figure. Maybe some have to be torqued down with the wrench. Who knows?
_matt < hopes it works out for ya...
Old Feb 20, 2004 | 10:50 PM
DsITR's Avatar
Ill offer my stupid advice..
When you change the filter do you put a bit of oil on the filter seal? This is supposedly needed so the filter seals to the threaded part properly.
95halx
Sep 5, 2012 12:35 PM
withlovealice
Feb 21, 2011 10:27 PM
El pimp chulo
Aug 6, 2006 04:31 PM
SIRef9[831]
Nov 4, 2004 10:01 PM
92TEGGYGSR
Jun 3, 2004 06:42 PM
