Replaced IACV 3 Times and still getting code 14/CEL
Old Feb 20, 2004 | 06:11 PM
Blaze45's Avatar
Brrraaaap!
Default Replaced IACV 3 Times and still getting code 14/CEL
I dont have an issue with it idling like it should, it useually drops right down to 500-750rpm, no problem. It also idles like it should when its cold usually round 12-1350rpm... I have reset the ecu (a lot) and replaced the valve 3 times, this time with one that I KNOW works, I tested the IACV for volts, but I dont seem to be getting anything..... I dont know what to do now but run a wire directlty from the ECU to the IACV, if any one knows the pin outs for a non obd PR4 for the IACV, please post them up. I am getting sick of my CEL>
tia
Blaze
Old Feb 20, 2004 | 11:07 PM
chameleon's Avatar
Default Re: Replaced IACV 3 Times and still getting code 14/CEL (Blaze45)
check on http://www.hybridgarage.com for the pinout of a gsr odb1 ecu should be the same locations.
Old Feb 21, 2004 | 04:16 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Replaced IACV 3 Times and still getting code 14/CEL (chameleon)
The pin outs are the same for a VTEC ECU and one that is OBD1? I have the non obd PR4....
Blaze
Old Feb 21, 2004 | 07:21 PM
Qfactor's Avatar
have you tried a different ecu, if wiring checks out fine then most likey you have a fried IAC driver(transistor) inside the ecu open it up and check for any burn components. good luck meng!!
Old Feb 21, 2004 | 08:15 PM
PnX-R's Avatar
To quickly check to see if the IAC is working, I usually just make sure the engine is running and turn on the AC or crank the Power Steering.. Either one should cause a load and the PCM should compensate by moving the IAC..
h0nda n00b
Engine Management and Tuning
Feb 27, 2014 09:13 AM
corps909k
Mar 25, 2009 09:56 AM
ludatic
Nov 2, 2003 10:46 PM
c8r9x
Aug 9, 2003 12:16 PM
