ECU CODE #2
Old Feb 20, 2004 | 04:27 PM
ENeRg3Tic's Avatar
Default ECU CODE #2
got a jdm b16 in a crx and it is throwing a code 2
i understand that this is the tdc sensor or sumthin like that .......
could this be why my car dies for no aparent reason and will start right back up again???? wen i changed the timing belt about a week ago i made sure that the crank lined up with the block and the cams lined up wit the holes in the splater guards...could it be distributor placement????
Old Feb 20, 2004 | 04:56 PM
ENeRg3Tic's Avatar
Default Re: ECU CODE #2 (ENeRg3Tic)
hello anywun out there
Old Feb 20, 2004 | 05:03 PM
onePOINTsix's Avatar
yes i'm out here, i say search
Old Feb 20, 2004 | 07:14 PM
fourthgenhatchB17's Avatar
Default Re: ECU CODE #2 (Sideout)
Code 2 on a obd-0 pr3 or pw0....isnt that a second O2 sensor problem?
Old Feb 20, 2004 | 08:35 PM
t25hatch's Avatar
Default Re: ECU CODE #2 (fourthgenhatchB17)
yes the answer to your question would be a distributor problem. That is exactly wat happened to my car. Check your ICM (ignitor) in your distributor, also check your ignition coil. Also check all grounds (chances are it won't be this, but check them anyways. Good Luck!
M3THTICAL(EF)
Jul 24, 2016 08:24 AM
kwizical
12
Mar 10, 2008 08:05 AM
ohiojack
Nov 4, 2007 04:40 PM
alexb16hb
Jul 22, 2005 05:15 PM
Spade
Jul 30, 2002 02:05 PM
