88-91 Cluster wiring....need info...
Old Feb 20, 2004 | 02:11 PM
*Boostwerks*'s Avatar
Default 88-91 Cluster wiring....need info...
Do the 88-91 clusters (the ones with tachs of course) have the same pinouts on the plugs?
I'm doing a 01 ITR cluster swap into my 91DX, but the pinouts I have were only "confirmed" on a 88.
Anyone have this information?
Also...
my 89DX does not have a tach...but I have my left over 91DX cluster...simply put...can I throw her in there with no wiring changes?
Old Feb 21, 2004 | 06:30 PM
Bump for info.
Old Feb 21, 2004 | 07:03 PM
CrowerRex's Avatar
Default Re: (Bryson)
Here are this pin locations on a 90-91 civic
12 pin connector:
1) Blue-tach
2)White/Blue-Volts
3)Black/Yellow-12v power
4)green/Orange-Check Engine
5)yellow/Red-Oil Light
6)Green/Red-E brake
7)Green/Red-Door Light
8)Red-Dash-Dash Lights
9)Red/Black-Dash Lights
10)Yellow/Green-Water Temp.
11)red/Blue-High beam
12)Green/Blue-Turn Signal Left
8 Pin connector:
1)Green/Yellow-Right Turn Signal
2)Yellow-12v Power
3)Yellow/white-Feul Gauge
4)Not Used
5)Green/black-Trunk light
6)Not used
7)yellow/red-Speed sensor
8)Black-Ground
oh and for the 91 cluster in the 89 forget about just plugging it in, you need to re-pin the plugs in the 89 to the locations for the 91. You have both now so just cross-reference them!
Old Feb 21, 2004 | 07:17 PM
Thats exactly what I needed!
Thanks a lot man!
Old Feb 21, 2004 | 08:25 PM
e-thuggin posour's Avatar
Any wiring changes for 89 si cluster to fit 89 std hatch?
Sorry to interupt. it seems that you got what you came for,
no sense in making a new thread for this question.
thank you.
Old Feb 21, 2004 | 08:34 PM
CrowerRex's Avatar
Default Re: (Fromda80's)
No changes in wiring are required to swap an 89 si cluster into the 89 std hatch. It's just a plug and play affair!
Any other q's man?
Old Feb 21, 2004 | 08:44 PM
Default Re: (CrowerRex)
yeah...where do babys come from?
(no need to answer)
thank you, kind sir.
Old Feb 21, 2004 | 08:50 PM
CrowerRex's Avatar
no pr man!
Old Feb 21, 2004 | 08:52 PM
xtrafastcivic's Avatar
change your avatar please ...
Old Feb 21, 2004 | 08:54 PM
CrowerRex's Avatar
Default Re: (XtraFastCRX)
no pr, didn't know someone else had it.
kcrxxx
Apr 2, 2008 08:13 PM
Iceycrx
Mar 26, 2006 06:36 AM
chadmasterc
Jun 4, 2005 09:42 PM
RTW DC2R
May 23, 2004 06:20 PM
