88-91 tansmission question
Old Feb 20, 2004 | 12:10 PM
DualCamDan's Avatar
Default 88-91 tansmission question
i have a 90 crx si and i've been looking for a transmission with out not much luck. the thing is i know that the 88 tannys are different than the 90 or 91, but what about an 89 si tans? are 89-91 all the same and 88 diff? or 88-89 the same and 90-91 the same? i've tryed to search some w/o any real luck. please some one help!
Old Feb 20, 2004 | 12:22 PM
EL Vap133's Avatar
Default Re: 88-91 tansmission question (whitey_4g)
From what I have heard, the 88 is the only outcast, the 89-91 are the same....
Old Feb 20, 2004 | 12:25 PM
I Gotta Question's Avatar
Default Re: 88-91 tansmission question (EL Vap133)
not exactly there is somethin in the tranny of the 89 thats diff i dont remember what but you cant use somethin off the 89 on a 90-91 somethin like that
DualCamDan's Avatar
so i can use an 89 tansmission w/ my 90 flywheel and clutch. is that right?
Old Feb 20, 2004 | 12:28 PM
DualCamDan's Avatar
Default Re: 88-91 tansmission question (I Gotta Question)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">not exactly there is somethin in the tranny of the 89 thats diff i dont remember what but you cant use somethin off the 89 on a 90-91 somethin like that
it looks as if i use the clutch and flywheel out of a 90 it'll work otherwise i have to use an 89 set up....
Modified by whitey_4g at 9:51 PM 2/20/2004
Old Feb 20, 2004 | 12:53 PM
WONG FRIED RICE's Avatar
88-89 trannies are the same
90-91 is the same
Old Feb 20, 2004 | 01:01 PM
Default Re: 88-91 tansmission question (JDMB16ACRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMB16ACRX &raquo;</TD></TR><TR><TD CLASS="quote">88-89 trannies are the same
90-91 is the same
not exactly, the 88 is diff from all of em and the 89 is diff from all of em the 90 and 91 are the only ones that are the same.
in your case, yes you can use an 89 tranny on your 91 using the 89-91 flywheel and the 89-91 clutch.
Old Feb 20, 2004 | 01:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Gotta Question &raquo;</TD></TR><TR><TD CLASS="quote">
in your case, yes you can use an 89 tranny on your 91 using the 89-91 flywheel and the 89-91 clutch. </TD></TR></TABLE>
when i changed my original tranny, it was an L3 tranny, i got another L3 tranny off of a 89 Si... so i thought they were the same...&lt;shrug&gt;
Old Feb 20, 2004 | 09:41 PM
when i changed my original tranny, it was an L3 tranny, i got another L3 tranny off of a 89 Si... so i thought they were the same...&lt;shrug&gt;</TD></TR></TABLE>
yeah the splines are the same but once you get inside the tranny with the gears and syncro mesh then the stuff tends to not match up right but yoiu can use a 89 clutch with a 90 tranny so on and so for just not with the 88.
Old Feb 21, 2004 | 06:25 AM
jlicrx's Avatar
all 89-91 Si transmissions are identical, externally and internally - most of the 88's are internally the same as 89-91 (although i have had one with the smaller differential bearings like the DX), the only difference is the 21 splines on the input shaft instead of 20 on the 89-91
mengy007
Aug 25, 2007 03:38 PM
rxxx7
Dec 2, 2005 09:44 PM
Gant
Mar 11, 2005 07:11 PM
user 98292739
26
Oct 20, 2004 12:40 AM
Project_ED8
Mar 19, 2004 02:21 PM
