Who can figure this out!
Old Feb 20, 2004 | 11:55 AM
Elvis1977's Avatar
Default Who can figure this out!
Ok, i have a 98 accord with 116k 4-cyl. When the engine is relatively cold and i start my engine I get a strange squeek/screatch for only half a second and the noise goes away. When the engine is warm/hot no noise at all. Alternator and power steering belts new and tension seems ok. The noise COULD be coming close to the starter area. Could it be the starter? Do starters make these strange squeeky noises? Or is it a belt or power sterring pump? Thanks.
Old Feb 20, 2004 | 12:01 PM
Mike813's Avatar
Default Re: Who can figure this out! (Elvis1977)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elvis1977 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, i have a 98 accord with 116k 4-cyl. When the engine is relatively cold and i start my engine I get a strange squeek/screatch for only half a second and the noise goes away. When the engine is warm/hot no noise at all. Alternator and power steering belts new and tension seems ok. The noise COULD be coming close to the starter area. Could it be the starter? Do starters make these strange squeeky noises? Or is it a belt or power sterring pump? Thanks.</TD></TR></TABLE>
you sure its a squeak and not a buzz??
Old Feb 20, 2004 | 12:04 PM
Elvis1977's Avatar
Default Re: Who can figure this out! (Mike813)
I would say a buzzy-squeak, but goes away quickly after startup.
Old Feb 20, 2004 | 12:08 PM
Mike813's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elvis1977 &raquo;</TD></TR><TR><TD CLASS="quote">I would say a buzzy-squeak, but goes away quickly after startup.</TD></TR></TABLE>
its not your abs is it?? thats the only thing that makes those funky noises under my hood...
Old Feb 20, 2004 | 12:12 PM
Elvis1977's Avatar
don't have abs. The noise comes instantaniously after startup and disapears quickly. Please give me some clues. Do starers make this squeek noise at startup or is it a belt?
Old Feb 20, 2004 | 12:16 PM
Mike813's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elvis1977 &raquo;</TD></TR><TR><TD CLASS="quote">don't have abs. The noise comes instantaniously after startup and disapears quickly. Please give me some clues. Do starers make this squeek noise at startup or is it a belt?</TD></TR></TABLE>
i really cant help you on this one sorry, if you can directly pinpoint the location im pretty sure someone has the same problem...gluck
Old Feb 20, 2004 | 01:11 PM
RotaryBzzzz's Avatar
have you ever replaced the starter? Had any problems with it before?
If so, it might be the starter-arm gnashing on the flywheel teeth for a split second.
It happens quite often with so-so rebuilt starters.
Old Feb 20, 2004 | 02:10 PM
Nick H's Avatar
New User
Default Re: Who can figure this out! (RotaryBzzzz)
sounds belt related to me...the starter would grind and be more of a mechanical sound than a high pitched squeeling...i know b/c mine does that on startup occasionally...go over your belts again and make sure they are all tensioned properly one last time...also, how long's it been since the timing belt has been changed???
Old Feb 20, 2004 | 02:48 PM
damntired42's Avatar
is it a buzzy squeek like a bee after a mouse or more like a wasp after a dry hinge? you sure it isnt a sip pop? or maybe even a click spat? sometimes mine makes a hummm screech but thats only because my cd skips while braking. If i were you i would narrow down the possiblilitys to a more definate decible or tone. good luck anyway.
Old Feb 20, 2004 | 03:45 PM
RUBZERK's Avatar
Default Re: Who can figure this out! (damntired42)
Replace your belt. It may be slipping.
Old Feb 20, 2004 | 04:12 PM
D21X's Avatar
Default Re: Who can figure this out! (RUBZERK)
get some WD-40 or some lubricating spray, and spray your pullies, the center part. i usually have some squeak because its cold out and it goes away when the car has been warmed up. goodluck!!!
Old Feb 23, 2004 | 06:39 AM
Elvis1977's Avatar
Default Re: Who can figure this out! (Nick H)
Your absolutely right. It was the alternator belt. I re-tensioned and everything is normal. Thanks.
Dm914
Dec 28, 2015 03:31 PM
K roun
Apr 23, 2014 08:46 AM
goldfinger93030
Jan 14, 2010 03:15 PM
94hondaon16's
Aug 11, 2008 03:16 AM
