Pinouts for Driver's side window switch for HB/Coupe
I just purchased this car and the person who previously owned it put in power windows with JDM switches. I bought a USDM switch for the drivers side because I accidentally broke it and I noticed the pinout is different. I have the factory manual for a 92 civic but in the power window section it only lists 4 door switches. I need the pinout and wire colors for the drivers side switch if anyone can help.
Damn nobody can help me with this. If this were my WRX I would have like 20 replies already. Damn car wish it never got stolen. Does anyone have a manual for a 93 coupe that has the pinouts and wire colors.
From: Why so you can pretend like youre interested, FL/OK
Blue/Yel Blue/Green White/Yel Empty
Blk2 Blue/Blk Blue Red/Yel Blk3 Red/blue
4 Pinouts on the top
6 Pinouts on the bottom
The layout is as if you were looking directly at the pinout for the wire harness and not that of the master switch for the windows (flip switch upside down on the controls and the layout above is the pinout).
I did the pinout as described above however I can only get the drivers switch to work with the passanger side using the drivers side button. This car is a freaking headache. On my way to the dealer to see a newer version manual if at all possible. I dont think thats gonna work though. The problem comes from the fact that the kid I bought the car from put in the power windows and used JDM switches I am unsure if the motors are JDM too. However since my JDM switch got broken I had to get a USDM one for the drivers side and now I am freaking lost as how to get these damn things working again. If you can help me out with my dilemma I would be more than appreciative.
Sounds backsward and somewhat confusing, since the original switch is on the passenger side I will take a look at both diagrams for the driver and passenger side and see if I can give you more information. It might be easier if you can find out which colors wires control what. I will check to look for that information as well.
Man I would really appreciate any help you can give me. I have a friend that is like a wiring guru that has been helping me try to fix this damn problem( has been working with car stereo's and alarms professionally for the past 8 years or so). So far we are both lost .
On the driver side master switch....
White/Yellow----(left side-power)
Black------(ground)
"all you have to do is plug in all the plugs to the driver side door and just wire these 2 wires and you already have power.."
For passenger window on master switch:
Blue/Black (right side-power)
Blue/Green---(motor up/down)
Blue/Yellow----(up/down)
"In able to control the passenger side window fron the master switch, you need to wires up these 3 wires (color match)..."
hope this will help you casue i have USDM power window setup in my car with OEM door lock and OEM wiring...
i also have done the JDM one's too..and it basically the same...if you need anymore info, just holla at me.
Black------(ground)
Thanks I am gonna give my friend this info when he gets here and see if this helps. However do you have the pinout for these switches (drivers side is USDM switch where as Pass. side is a JDM switch) or can you tell me what does what on the switch. I have been battling this damn thing for the past week and have almost given up.
so you saying that you have 2 master switch? a USDM and a JDM? well then the jdm master switch is the same as the USDM one''just color match the wires htat i stated in the above post...and tap them or connect them together...then you can be able to control both window from either side...
is this what you wanted to know?
not exactly. I have a JDM passanger side switch for pass. window only and I had a JDM master switch but that got broken so I got a used USDM switch and the pinouts were different on the switches. But, my friend finally figured it out tonight. We both dont understand it but it works. Thats all that matters is that both sides work. I appreciate all the help you guys gave me. This was just an inherited problem from a kid that did things all ghetto like. Now everything is up and running not factory like I would prefer but it does work. Anyways thanks again.
spnej1
16
Mar 3, 2008 06:32 AM
RARE_EG2
Dec 30, 2007 06:58 PM
