H22 or F20B
Old Feb 20, 2004 | 01:39 AM
kevinm1981's Avatar
Default H22 or F20B
What makes the F20B better then the H22?
Old Feb 20, 2004 | 06:11 AM
v4lu3s's Avatar
RTFM
it is more rev friendly. thats about it.
whatmakes an h22a better?
LOTS more parts availability since it is an engine that was in the US market.
more displacement.
they are very similar engines in msot respects though.
Old Feb 20, 2004 | 06:40 AM
The_Todd's Avatar
Farts in the shower
Default Re: (v4lu3s)
I have heard the f20 is a destroked h22, thats the easiest way to describe it. Also the f20 is obd2.
Old Feb 20, 2004 | 08:26 AM
cd555's Avatar
Default Re: (VRDrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">I have heard the f20 is a destroked h22, thats the easiest way to describe it. Also the f20 is obd2.</TD></TR></TABLE>
So are some h22's
Old Feb 20, 2004 | 09:25 AM
v4lu3s's Avatar
RTFM
teh f20b has less stroke, but it also has an 85mm bore too and afaik it doesnt ahve FRM sleeves either, it alos uses a differetn injector as well.
Old Feb 20, 2004 | 09:27 AM
TOAB's Avatar
not sure but i heard the f20b has like no midrange power and needs to rev up like a b series to make its power
Old Feb 20, 2004 | 02:07 PM
Nick H's Avatar
New User
Default Re: (TOAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOAB &raquo;</TD></TR><TR><TD CLASS="quote">not sure but i heard the f20b has like no midrange power and needs to rev up like a b series to make its power</TD></TR></TABLE>
yeah it does, i believe redline is 8200 on the f20b's...
Old Feb 21, 2004 | 03:36 AM
kevinm1981's Avatar
Default Re: (Nick H)
won't most aftermarket parts for the h22 fit the F20B? and isn't the tranny a hydro not cable like the H series?
Old Feb 21, 2004 | 07:53 AM
TOAB's Avatar
Default Re: (kevinm1981)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevinm1981 &raquo;</TD></TR><TR><TD CLASS="quote">won't most aftermarket parts for the h22 fit the F20B? and isn't the tranny a hydro not cable like the H series?</TD></TR></TABLE>nope...
Old Feb 23, 2004 | 08:43 AM
v4lu3s's Avatar
RTFM
cams and valve springs, maybe manifolds will fit between h22a and f20b....
and both engines are hydraulic clutches with cable shifters.
honda has not done cable clutches since 1993.
Old Feb 25, 2004 | 11:12 PM
kevinm1981's Avatar
How much do F20B's cost? Aren't they like 3000 compared to 2000 for the H22?
Old Feb 26, 2004 | 09:11 AM
sponger1054's Avatar
Default Re: (farroutt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by farroutt &raquo;</TD></TR><TR><TD CLASS="quote">
So are some h22's </TD></TR></TABLE>
yea some are...but **** obd2
Old Feb 26, 2004 | 10:56 AM
TOAB's Avatar
for a complete swap ive seen them go for over 4k... not sure though i stopped shopping around for prices
Old Feb 26, 2004 | 11:58 AM
vasponger's Avatar
some parts do fit from the h22, header, cam gears, pulleys. not sure about internals though.
Old Mar 1, 2004 | 12:20 PM
grandel's Avatar
Default Re: (vasponger)
The parts in the head of the H22B are interchangeable with the f20B DOHC.
The JDM F20B actually comes in DOHC and SOHC.
The DOHC redlines at 7400-7600.
The Accords (Torneos) in my part of the world carry these engines.
Old Mar 1, 2004 | 12:58 PM
Nick H's Avatar
New User
Default Re: (grandel)
the part numbers are the same for the blocks as well, which suggests that the f20b merely uses a different rod/crank setup and slightly smaller pistons...
Old Mar 1, 2004 | 03:29 PM
v4lu3s's Avatar
RTFM
the f20b block is not an FRM block and has iron sleeves so the part # cannot be the same....
Old Mar 7, 2004 | 02:09 AM
kevinm1981's Avatar
So I should buy a obd1 closed deck JDM H22A?
Old Mar 7, 2004 | 06:35 AM
fizzbob7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grandel &raquo;</TD></TR><TR><TD CLASS="quote">The parts in the head of the H22B are interchangeable with the f20B DOHC.
The Accords (Torneos) in my part of the world carry these engines.</TD></TR></TABLE>
and the automatic f20b's make 180hp vs. the manual's 200hp......what's an h22b out of?
never seen anything about that
Trey Brown
Nov 18, 2007 12:14 PM
Tom123456
May 19, 2006 04:25 AM
95accordh22a
Mar 12, 2005 05:26 PM
ah789454
Jul 26, 2004 09:39 PM
