butterfly valve on gsr im not wired....
Old Feb 20, 2004 | 12:15 AM
B18Cej1's Avatar
Default butterfly valve on gsr im not wired....
can anyone show me how to do this? where to wire on the im and where to plug into the ecu (p72)
thanks
Old Feb 20, 2004 | 12:20 AM
EG2 SiR's Avatar
Default Re: butterfly valve on gsr im not wired.... (B18Cej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Cej1 &raquo;</TD></TR><TR><TD CLASS="quote">can anyone show me how to do this? where to wire on the im and where to plug into the ecu (p72)
thanks </TD></TR></TABLE>
I am probably wrong seeing as I run a b16, but isn't it vacuum controlled?
Old Feb 20, 2004 | 12:35 AM
B18Cej1's Avatar
Default Re: butterfly valve on gsr im not wired.... (EG2 SiR)
it might be. im using a civic harness (ex) for my motor though so its not being controlled by ne thing i think. i heard u have to ground something then run another wire from the manifold to the ecu..
Old Feb 20, 2004 | 12:57 AM
Team 4R's Avatar
which year computer are you using..........? you need to run a power wire to the iab output on your particular ecu, and then run the black wire to any ground.... i spliced mine into the ground for the o2 sensor.
Old Feb 20, 2004 | 01:06 AM
B18Cej1's Avatar
Default Re: butterfly valve on gsr im not wired.... (Team 4R)
everything is 95, computer, car, engine. do u have pics of which wires (on the intake manifold or wherever) to run?
Old Feb 20, 2004 | 03:33 AM
dwnthehatch's Avatar
Sorry for the caps. This is all you have to do.
MOVE THE RED WIRE ON YOUR ECU SIDE HARNESS FROM A20 TO A17 FOR YOUR SECONDARY RUNNERS FOR YOUR INTAKE MANIFOLD. THEY SHOULD OPERATE AS SEEN HERE .
Old Feb 20, 2004 | 08:55 AM
B18Cej1's Avatar
Default Re: butterfly valve on gsr im not wired.... (dwnthehatch)
damn cant see the pic.. but thats all u have to do? does it matter that the wire harness is the civic harness?
Modified by B18Cej1 at 6:24 PM 2/20/2004
Old Feb 20, 2004 | 09:54 AM
white ex's Avatar
if you use the ex harness you use the plug that went to the purge control solenoid on your old motor and plug it into the iab solenoid on the gsr, then as dwnthehatch said just move a20 to a17.
Old Feb 20, 2004 | 09:55 AM
whoDAT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote">
MOVE THE RED WIRE ON YOUR ECU SIDE HARNESS FROM A20 TO A17 FOR YOUR SECONDARY RUNNERS FOR YOUR INTAKE MANIFOLD. THEY SHOULD OPERATE AS SEEN </TD></TR></TABLE>
that's what i did on my c1 swap, but for reasont the secondaries are still not working. wondering what the hell i did wrong
Old Feb 20, 2004 | 10:36 AM
B18Cej1's Avatar
Default Re: butterfly valve on gsr im not wired.... (white ex)
im lost i need pictures of the ecu wiring and positions and detailed instructions. sorry guys still new to all this.
Old Feb 20, 2004 | 11:05 AM
whoDAT's Avatar
if you would have SEARCHED...you would have came up with this...
https://honda-tech.com/zerothread?id=631748
Old Feb 20, 2004 | 11:06 AM
B18Cej1's Avatar
Default Re: butterfly valve on gsr im not wired.... (whoDAT)
i tried searching. im not good at it. all i found was skunk 2 intake manifolds. thanks for the find though! VERY HELPFUL. thank you
Modified by B18Cej1 at 8:56 PM 2/20/2004
Old Feb 20, 2004 | 12:19 PM
Turbo E's Avatar
i just zip tied mine open.
Old Feb 20, 2004 | 12:44 PM
EG2 SiR's Avatar
Default Re: (Turbo E 604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 &raquo;</TD></TR><TR><TD CLASS="quote">i just zip tied mine open. </TD></TR></TABLE>
and defeted the purpose of having a GSR mani????
Old Feb 20, 2004 | 01:41 PM
Turbo E's Avatar
Default Re: (EG2 SiR)
well I gained 1/2 a second in the 1/4 so i guess it was worth it.
Old Feb 20, 2004 | 01:44 PM
EG2 SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 &raquo;</TD></TR><TR><TD CLASS="quote">well I gained 1/2 a second in the 1/4 so i guess it was worth it.</TD></TR></TABLE>
just curious, was that compared to them not opening at all? or having them functioning correctly?
Old Mar 2, 2004 | 03:11 PM
Turbo E's Avatar
ran consistant 14.0 that day. P28 ECU so no 2nd runners.
10¢ worth of zip ties later 13.5 - 3 times in a row. no other mods or changes.
I don't think i got that much better racing in between runs.
proof enough for me.
Old Mar 2, 2004 | 03:23 PM
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote">Sorry for the caps. This is all you have to do.
MOVE THE RED WIRE ON YOUR ECU SIDE HARNESS FROM A20 TO A17 FOR YOUR SECONDARY RUNNERS FOR YOUR INTAKE MANIFOLD. THEY SHOULD OPERATE AS SEEN HERE .</TD></TR></TABLE>
worked for me a long time ago. weeeeeeeeeeeeeeeeeeeeeeeee
Old Mar 2, 2004 | 03:33 PM
B18Cej1's Avatar
Default Re: butterfly valve on gsr im not wired.... (B CRUZ)
yep works now thanks everyone
BlackCivicEX
32
May 10, 2023 02:04 AM
liquidrider
Jul 29, 2009 01:55 PM
eg6madness
Nov 17, 2007 04:46 PM
Cornwhiskey
Apr 11, 2004 02:47 PM
