Maintanace questions
Old Feb 19, 2004 | 07:24 PM
M's Avatar
M
Default Maintanace questions
Hey everyone,
I'm a honda noob. I just got an 89 civic hatch (base model, no power anything, no a/c) for a daily driver. I need to change the timing belt and replace at least 1 cv boot.
I am wondering if it is common practice to change the timing belt and water pump at the same time, and if so what parts do i need to get.
Also is it a good idea to get split cv boots (easier install).
I've heard there is a guy on here that can get parts for dirt cheap so if anyone can refer me to him that'd be great. i'll post some pics of the car when i get home. It's not my only car so please no comments on modifying it because that's what my other cars are for, even though i'm sure it will get something change, just not the engine.
thanks for your help.
Old Feb 19, 2004 | 07:41 PM
EG8R's Avatar
Default Re: Maintanace questions (M)
When was the water pump done last?
If you are unsure it would not hurt to change it. No you don't have to change the t-belt and water pump at the same time. But the t-belt should be done every 96,000 km(not sure how many miles that is)
Not sure what you mean by split CV boots. All the ones I have seen are one rubber boot that gets held on with 2 bands...
Old Feb 19, 2004 | 08:01 PM
M's Avatar
M
I am not sure when the water pump was done last, probably last time the belt was changed. i'm not goiong to risk it though. I'll swap it.
the split cv's you can slip on the halfshaft instead of having to remove the steering nuckle and slip them on the halfshafts.
Old Feb 19, 2004 | 08:18 PM
viper_2_4's Avatar
I think you have to check to see if the joint has gone bad, if its gone bad I think you have to replace it
nightfawl
Jan 22, 2015 06:04 PM
EGCivicChicago
17
Jan 21, 2007 06:45 AM
Kryptonite
Jul 5, 2005 10:08 PM
98LS4dr
Jul 30, 2003 09:45 PM
newtegowner
Oct 18, 2001 12:21 PM
