Help A Canadian Guy Out - Having Trouble Finding Shock Absorbers
Old Feb 19, 2004 | 07:23 PM
WeaponR
Guest
Posts: n/a
Default Help A Canadian Guy Out - Having Trouble Finding Shock Absorbers
I have an RS integra with the ITR suspension swap. I am having trouble locating part #'s for an ITR strut setup. We don't have the same amount of selection that the U.S. does, so i'm going to have to order them from there. I am trying to be as well informed as possible so I don't get the wrong ones.
I am looking for any of these three strut makes - if you could provide a model #, it would be greatly appreciated. I went to http://www.shox.com, and even they don't have a distinction between "INTEGRA" and "ITR" categories.
I am looking for the part #'s to these struts (front and rear):
Tokico HP
KYB GR2
KYB AGX
Thanks!
Old Feb 19, 2004 | 07:31 PM
DsITR's Avatar
Default Re: Help A Canadian Guy Out - Having Trouble Finding Shock Absorbers (WeaponR)
I know the Koni Yellow part # if you need that ...
I can't seem to find any of the KYB/Tokico.
on a few of the shocks listed, it does say TYPE R ONLY.. but not all.
EDIT just found this
they make AGXs for the R? I wasn't aware of that. all the application charts I've seen don't show these parts for the R. what are the part #'s for the front and rears shocks? thanks!
https://honda-tech.com/zerothread?id=119704
I would drop the guys @shox.com an email.
Old Feb 19, 2004 | 07:54 PM
WeaponR
Guest
Posts: n/a
Thanks for your help. I'm not looking to spend a lot of money, so i'd prefer to get an OEM shock (although I would opt for the AGX's if I can find their part #).
Old Feb 20, 2004 | 09:50 AM
WeaponR
Guest
Posts: n/a
bump
Old Feb 20, 2004 | 09:58 AM
WeaponR
Guest
Posts: n/a
Will the 1988 CRX si ones fit? I remember using 1988 CRX LCAs when I did my ITR suspension swap
Old Feb 20, 2004 | 09:59 AM
RTW DC2R's Avatar
i dont think they make AGXs for the R.
Old Feb 20, 2004 | 10:03 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (WeaponR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WeaponR &raquo;</TD></TR><TR><TD CLASS="quote">I'm not looking to spend a lot of money, so i'd prefer to get an OEM shock</TD></TR></TABLE>
You can look up stock part numbers here.
Old Feb 20, 2004 | 01:33 PM
110 South's Avatar
For the ITR, the tokico part number for the rear are the same as the 88 CRX, which uses the ball type rear shock like the type-r. Essentially, you can use any rear shock for the 88 CRX which will fit.
While at inlinefour, I sold many of them this way and never had any complaints. However, they are not valved differently for the ITR being that it is heavier in the rear than a CRX and that was something I always brought to the customers attention. Many of the people I sold them to were using a sleeve type coilover setup, so they could increase the rear spring rate to compensate. You won't have any problems with that setup.
score10
Jul 22, 2010 12:37 PM
honda93
Honda Civic (2006 - 2015)
Nov 28, 2006 04:59 AM
freshjuice02
Dec 26, 2004 05:44 AM
wm5holla
Jul 30, 2003 05:44 PM
Chairman Kaga
Mar 21, 2002 02:36 PM
