99 gsr with 96 gsr motor swap problems PLEASE HELP
Old Feb 19, 2004 | 07:11 PM
toyhouse's Avatar
Default 99 gsr with 96 gsr motor swap problems PLEASE HELP
i have a 99 4door gsr and i put a 96 gsr motor in it.
my tach and speedomitor dont work.
my front passanger side door power window and power mirror dont work.
my clock and dome light dont work.
i don't have a jumper for the ecu and i'm not sure if you need one.
dose anyone know if i need an obd2b to obd2a jumper?
if i it is the computer will it fix all the problems i'm having?
Old Feb 20, 2004 | 02:00 PM
toyhouse's Avatar
Default Re: 99 gsr with 96 gsr motor swap problems PLEASE HELP (toyhouse)
ANYONE?
Old Feb 20, 2004 | 04:25 PM
Katman's Avatar
I assume you tried using your 99 GSR ecu with the 96 engine, yeah?
make sure all your grounds are grounded ?
Old Feb 22, 2004 | 02:31 AM
toyhouse's Avatar
Default Re: 99 gsr with 96 gsr motor swap problems PLEASE HELP (Katman)
no i have a 96 motor and a 96 ecu.
Old Feb 22, 2004 | 02:32 AM
toyhouse's Avatar
but i also used a 00 interior sub harness.
Old Feb 22, 2004 | 06:23 AM
turboxsi's Avatar
Have you checked your fuses. Sounds like a fuse with everything you described being out or not working. Give the fuses a look, before making things difficult on yourself.
Old Feb 22, 2004 | 06:42 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyhouse &raquo;</TD></TR><TR><TD CLASS="quote">but i also used a 00 interior sub harness.</TD></TR></TABLE>
That's your problem then.
You shoulda kept your 96 interior harness in place....why did you change the interior harness???
Old Feb 24, 2004 | 04:48 PM
toyhouse's Avatar
the harness would be a 99 but anyways it was changed cause it was cut at the firewall.
All the fuses are fine.
Old Feb 24, 2004 | 06:18 PM
jdm_boost's Avatar
The ecu and harness that came with the car will work on your "new" motor. I don't know why you changed it and I'm guessing that's where the problem is. Not because it's the wrong one but you didn't wire everything right. As far as your windows, clock, and dome light aren't working as the engine wiring harness doesn't deal with those systems. For your speedometer look on the top of the back of the transmission and make sure the speed sensor is hooked up.
Old Feb 25, 2004 | 11:47 PM
toyhouse's Avatar
Default Re: 99 gsr with 96 gsr motor swap problems PLEASE HELP (jdm_boost)
I had to change the harness cause it was cut at the firewall and i didn't have the other end. So it's a new harness.
The can didn't come with a motor or ecu thats why i have a 96 motor and ecu. At the time that was the only obd2 motor that i could find.
I'm trying to get a 99 ecu but no one has one. I can get a 99 si ecu but i'm not to sure it's going to work.
Anyone know if i can use the 99si ecu?
Old Feb 27, 2004 | 12:01 AM
Tadeh's Avatar
Im sure Katman can get you something, wouldn't a chipped p28 with stock GSR program work? (and harness)
Old Feb 27, 2004 | 01:39 AM
eyeamvic's Avatar
So basically everything on your interior doesn't work? Sounds like something an ECU won't fix. I would think the 96 & 99 interior harness would be the same, but for some reason I think this is where the problem lies.
Old Mar 5, 2004 | 01:51 PM
toyhouse's Avatar
problem solved.
2 plugs on the sub-harness were mixed up.
That was the only problem.
hmmm.....
next time i'll have to remember that.....
Thanks everyone for trying to help me out
Old Mar 6, 2004 | 01:37 AM
Katman's Avatar
which plugs were they ?
ants4g63
27
Apr 9, 2009 11:03 AM
heefro757
Dec 18, 2008 02:19 PM
danteisme
Oct 12, 2003 10:54 AM
ImportechPerformance
Jan 15, 2002 09:08 PM
