I don't know how to use an impact driver
Old Feb 19, 2004 | 06:43 PM
SLeePeR012's Avatar
Default I don't know how to use an impact driver
Ok, yeah I think I'm dumb.
For some stupid reason my non-numatic impact driver isn't workin for me.
I think I'm using it right.
When I pound it with the end of the hammer, the bit doesn't turn.
The screws Im tryin to impact off are the ones in the hub to change the rotors.
Any ideas?
I am pushing the driver down and hitting it, and yes I know how to change/reverse the driver position.
Old Feb 19, 2004 | 06:48 PM
Average Al's Avatar
hit it harder
maybe not giveing it enough pressure to turn the screw?
Old Feb 19, 2004 | 06:49 PM
mblis82's Avatar
Default Re: I don't know how to use an impact driver (SLeePeR012)
You have to use a BIG hammer and hit it pretty hard. Try at least a 5lbs baby sledge hammer and all will be good.
dfoxengr's Avatar
Default Re: (Average Al)
you have to turn the body of the driver while you are hitting it. turn the way you want it to go
Old Feb 19, 2004 | 06:50 PM
Jimmy's Avatar
Global Moderator
Make sure its going the rihgt direction...I also bought one from autozone for the same purpose you are using it...I payed 9.99
As people said above you need to hit it pretty hard and i think it will work for you
Goodluck bro
Old Feb 19, 2004 | 06:58 PM
SLeePeR012's Avatar
So turn as I POUND it?
.....back to the garage I go; thanks.
Old Feb 19, 2004 | 07:04 PM
Grip's Avatar
yea if you play with it you will see that is turns either way..put the eend into the screw and turn the end of the impact driver towards loosen or to the left then hit it..your gonna have to hit it hard and a few times before it does anything..your using the impact of the blow to break it loose while at the same time your trying to loosen the screw..you can also try tightening it a little to break it loose..this usually works
dfoxengr's Avatar
yes you HAVE to turn it
Old Feb 19, 2004 | 07:08 PM
SLeePeR012's Avatar
Wait, how do i turn as I hit it?
Sorry, this thing didn't come with ANY instructions
Don't you just set it and press down and pound it?
...back to the garage......
EDIT: ok I got the instructions
Thanks grip, I'll see ya saturday.
Modified by SLeePeR012 at 10:23 PM 2/19/2004
Old Feb 19, 2004 | 07:11 PM
mjrage's Avatar
Get some PB and give it a shot, also get some anti seize for when you are done.
Old Feb 19, 2004 | 07:13 PM
dfoxengr's Avatar
no grab the body of the driover, where the knurling (grip) is on it, and turn left while u hit to loosen, and right while u hit to tighten
NonovUrbizniz's Avatar
Loved
Default Re: I don't know how to use an impact driver (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">yes you HAVE to turn it</TD></TR></TABLE>
I've NEVER turned an impact driver while hitting it. Always work just fine for me.
Old Feb 19, 2004 | 07:16 PM
dfoxengr's Avatar
Default Re: I don't know how to use an impact driver (NonovUrbizniz)
maybe you uncontiously do as you hold it, or maybe yours is super cool, lol. but they are made to loosen and tighten, hence the need to turn. unless you have a sh*ty one-way one???
Old Feb 19, 2004 | 07:25 PM
SLeePeR012's Avatar
So as I rotate my wrist to loosen I also keep banging on the end as I turn?
Old Feb 19, 2004 | 07:27 PM
dfoxengr's Avatar
yes geez its really simple rotate and hit simultaneously.
Old Feb 19, 2004 | 07:49 PM
mike93eh
Guest
Posts: n/a
holy ****!
newbie thread of the year award..
Old Feb 19, 2004 | 07:52 PM
dfoxengr's Avatar
Default Re: (mike93eh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh &raquo;</TD></TR><TR><TD CLASS="quote">holy ****!
newbie thread of the year award..</TD></TR></TABLE>
ha. and after the eighth try....
did you finally get it to work dude. i feel kinda bad for you
Old Feb 19, 2004 | 07:57 PM
SLeePeR012's Avatar
I think it's broken; ahh well, I think Im just gonan drill the heads off.
Not even two months and making wise cracks already
I predict a long and prosperous future on HT.
...Thats not a good thing assclown.
Old Feb 19, 2004 | 08:00 PM
mike93eh
Guest
Posts: n/a
Default Re: (SLeePeR012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLeePeR012 &raquo;</TD></TR><TR><TD CLASS="quote">I think it's broken; ahh well, I think Im just gonan drill the heads off.
...Thats not a good thing assclown.</TD></TR></TABLE>
stfu n00b. its an internet message board, just because it says i registered 2 months ago doesnt really mean anything.
you have 96% huh? maybe you should have a dose of your own advise.
Old Feb 19, 2004 | 08:07 PM
SLeePeR012's Avatar
Pathetic.
Old Feb 19, 2004 | 08:08 PM
dfoxengr's Avatar
guhh. the old quote ..."arguing online is like running a race in the special olympics, even if you win, youre still retarded"
Old Feb 19, 2004 | 08:10 PM
jcarothers's Avatar
and all of the sudden everyone is a hard ***..
back on topic, I never had to turn one before... just hit it and it worked
Old Feb 19, 2004 | 08:13 PM
SLeePeR012's Avatar
Default Re: (jcarothers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcarothers &raquo;</TD></TR><TR><TD CLASS="quote">and all of the sudden everyone is a hard ***..
back on topic, I never had to turn one before... just hit it and it worked</TD></TR></TABLE>
Yea tell me about it...I almost feel sorry for them.
But my friend also said you do NOT have to turn it.
I tried everything I've never seen this thing budge.
I might consider the fact that those screws have never been removed...5years old pretty rusted, maybe it just can't torque it.
Old Feb 19, 2004 | 08:15 PM
dfoxengr's Avatar
by turn i hope you all know i dont mean spin it around, simply apply pressure in the desired direction.
Old Feb 19, 2004 | 08:16 PM
jcarothers's Avatar
I had to use one on mine. worked like a charm.. you jsut have to hit it *really* hard.
and jsut a thoguht, but why would you use an impact driver to tigthen something? seems like you'd overtighten everything with it..
