Losing Oil Pressure
Old Feb 19, 2004 | 05:18 PM
3.8turbo's Avatar
Default Losing Oil Pressure
I finally installed a oil pressure gauge after noticing my oil light coming on after driving the car for a while. Seems as tho after the car warms up or as it gets to Operating temp. It slowly loses oil pressure. And guesses as to what this may be?
Any help is appreciated.
Old Feb 19, 2004 | 05:28 PM
speedworks's Avatar
Default Re: Losing Oil Pressure (3.8turbo)
rod bearings are extremely worn. pull the oil pan and look in the bottom for bearing material.
Old Feb 19, 2004 | 06:37 PM
3.8turbo's Avatar
Default Re: Losing Oil Pressure (speedworks)
Thanks. Does this mean I will need a new crank?
Old Feb 19, 2004 | 07:44 PM
InjectedPerformance's Avatar
We sell parts.
NO. The material of the bearings is by far softer than crank.
Old Mar 6, 2004 | 10:43 AM
LudEcrous's Avatar
I have the same problem with low oil pressure at warm idle....I have a built h23 turbo. I thought it was my oil pickup..dropped my pan and checked it and everything was fine. There was a little dent in my oil pan but i pounded it out. Same results though.
So do we rule out the oil pump? so i should plastigauge my rod bearings....i think the clearances are too loose when it was put together.
What should be my next step in evaluating this problem?
Thanks.
ndex
Jan 28, 2013 06:31 AM
bOOsT-FeIn
11
Oct 30, 2006 06:00 PM
wezzel19
Oct 9, 2006 09:05 AM
Penny
Mar 9, 2004 06:38 PM
EG*MonKEY
Nov 10, 2002 09:46 AM
