GSR cluster questions!
Old Feb 19, 2004 | 04:49 PM
DC2-JRSC'd's Avatar
Default GSR cluster questions!
Im thinking about putting a gsr cluster into a 89 si and i was wondering will the tach and speedometer still be accurante since the 89 stock cluster redlines at 6.5k and goes to 8k and the gsr redlines at 8k and goes all the way to 9.5k ? Same questions for the speedometer. Thanks!
Old Feb 20, 2004 | 07:28 AM
DC2-JRSC'd's Avatar
Default Re: GSR cluster questions! (dan4g63)
anyone?
Old Feb 20, 2004 | 07:36 AM
virginia_dude's Avatar
Tach wil be as acurat as a factory tach will be. Just remember that doesnt raise the redline of whats under the hood at all. Same with speedo. Honda all use the same drives for the most part as I understand.
Old Feb 20, 2004 | 07:45 AM
Wes V's Avatar
Default Re: GSR cluster questions! (virginia_dude)
In regards to the tach, you could loose accuracy if you used a tach from a 6 cylinder car in a car with a 4 cylinder (which you are not).
As for the speedometer; as I understand it, you have to add the VSS sensor in place of the original speedometer cable. What would throw out the accuracy would be the over-all diameter of your wheels. Other than that, you should be OK.
Wes
Old Feb 20, 2004 | 07:48 AM
Default Re: GSR cluster questions! (Wes V)
Yes. point I should have made, 4 cyl for 4 cyl etc.
Old Feb 20, 2004 | 09:22 AM
*Boostwerks*'s Avatar
I'm actually doing a 01 ITR cluster swap right now into my 91 DX.
Its looking fairly easy so far, as long as you know how to read pinouts, and be fairly sufficent at soldering.
Here is all the info you need to know...
https://honda-tech.com/zero...55473
Old Feb 24, 2004 | 06:34 PM
DC2-JRSC'd's Avatar
thanks
Old Feb 24, 2004 | 07:51 PM
ScottEK's Avatar
Default Re: (dan4g63)
Yep on the speedo you have to add in VSS, so you need VSS from another car and get the plug for it too off the harness of the car. It has 3 wires you have to run.
I'm doing this right now too with a 97 cluster it looks great mocked up, I counted the other day and I think there were only 16 wires to solder in all.
Old Feb 24, 2004 | 08:33 PM
APEX CRX's Avatar
Default Re: GSR cluster questions! (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">I'm actually doing a 01 ITR cluster swap right now into my 91 DX.
good thread/ going to do a USDM ITR cluster into my 89 CRX Si
Old Feb 24, 2004 | 08:46 PM
GOLDBERG's Avatar
can ya post some pics after u r done?
Old Feb 25, 2004 | 08:39 AM
Default Re: GSR cluster questions! (GOLDBERG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG &raquo;</TD></TR><TR><TD CLASS="quote">
can ya post some pics after u r done?</TD></TR></TABLE>
Of course! hehe.
And remember that the pinouts for the 88-89s ARE NOT THE SAME as the 90-91s. Just make sure you have the correct pinouts for your year.
GSR936
Dec 29, 2008 01:52 PM
Speed94
Jun 8, 2006 07:19 AM
Jesterian
24
Aug 25, 2005 04:04 PM
EpDarks
Nov 17, 2002 09:34 PM
