replacing my struts! ran into a problem i need help asap!
Old Feb 19, 2004 | 03:48 PM
arrowed's Avatar
Default replacing my struts! ran into a problem i need help asap!
the front struts wentfine but when i went to attempt the back struts the screws are extremely hard to take off... is there any thing that we can use? any more force and it will strip the screw. this is at the screw at the bottom of the strut and if it helps this is off a 91 civic
Old Feb 19, 2004 | 04:03 PM
BoOsted-Hatch's Avatar
Default Re: replacing my struts! ran into a problem i need help asap! (arrowed)
I had the same type of problem before in my Civic All did was used a air chisel and broke it off one of the ends and air chiseled the whole bolt out and just got some regular hardware that you can get at honda or a hardware store .It should be a 17mm.Hope it helps ...
Old Feb 19, 2004 | 04:18 PM
timmy8151's Avatar
Do a search on LCA bolts.
If you're bolts are seized, you're prob gonna have to cut them out.
If its not the LCA bolts, then use some PB blaster on the bolts.
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arrowed &raquo;</TD></TR><TR><TD CLASS="quote">the front struts wentfine but when i went to attempt the back struts the screws are extremely hard to take off... is there any thing that we can use? any more force and it will strip the screw. this is at the screw at the bottom of the strut and if it helps this is off a 91 civic</TD></TR></TABLE>
There bolts not screws , anyways you need to get a big pry bar on there, also blast them with pb blaster. Really no special trick besides muscles or air
Old Feb 19, 2004 | 04:21 PM
InjectedPerformance's Avatar
We sell parts.
Default Re: replacing my struts! ran into a problem i need help asap! (90blackcrx)
If the bolts are seized in the bushing, you will have to cut the ends off to get the shock out. Then you will have to take the control arm off, push out the old bushing with a press and press a new one in. The bushings are like 25 bux. Gl
Old Feb 19, 2004 | 04:22 PM
We sell parts.
Default Re: replacing my struts! ran into a problem i need help asap! (primo8998)
Also when using a new bolt make sure to put some antiseize on it for next time
Old Feb 19, 2004 | 06:04 PM
arrowed's Avatar
where could i get a PB blaster? right now i'm trying to hack it off with a dramel..
Old Feb 19, 2004 | 06:09 PM
arrowed's Avatar
any ideas of how to cut them off faster?
Old Feb 20, 2004 | 06:43 PM
Angle grinder or the dremel
tobe1424
30
Jul 23, 2007 05:42 AM
Jameson
Jan 20, 2007 07:55 PM
Blazin Civic
11
Jun 20, 2005 03:15 PM
DC231 Sean
Jan 20, 2005 07:59 AM
Traction
Jul 30, 2004 07:01 PM
