WWUD: 5th gear grind ONLY when dumping to a lower gear at higher revs/speeds
Old Feb 19, 2004 | 02:55 PM
Xymox007's Avatar
Default WWUD: 5th gear grind ONLY when dumping to a lower gear at higher revs/speeds
Think I should fix it now? It's not as if it happens all the time. Only when I decide to drop down to 4th at my cruising speed (80 mph), to gun around a slow poke that's hanging out in the left lane.
I'm sure it's my synchro.
Ah, I dunno what to do. I was really counting on buying used ITR springs/shocks/LCA and having them installed. Now, I may be looking at new sychro(s).
WWUD?
Old Feb 19, 2004 | 03:07 PM
LSTEG96's Avatar
Default Re: WWUD: 5th gear grind ONLY when dumping to a lower gear at higher revs/speeds (Xymox007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xymox007 &raquo;</TD></TR><TR><TD CLASS="quote">Think I should fix it now? It's not as if it happens all the time. Only when I decide to drop down to 4th at my cruising speed (80 mph), to gun around a slow poke that's hanging out in the left lane.
WWUD?</TD></TR></TABLE>
NOT that!
Old Feb 19, 2004 | 03:26 PM
svtec's Avatar
L D E S
Default Re: WWUD: 5th gear grind ONLY when dumping to a lower gear at higher revs/speeds (LSTEG96)
you can probably wait on the synchro for a little while.
Old Feb 19, 2004 | 04:01 PM
mrmonk's Avatar
Default Re: WWUD: 5th gear grind ONLY when dumping to a lower gear at higher revs/speeds (svtec)
did somone say SYNCRO???????????
Old Feb 19, 2004 | 04:23 PM
Andrew01's Avatar
Default Re: WWUD: 5th gear grind ONLY when dumping to a lower gear at higher revs/speeds (mrmonk)
put some GM syncromesh in the gear box and see what happens, should take care of that little grind.
svtec's Avatar
L D E S
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrmonk &raquo;</TD></TR><TR><TD CLASS="quote">did somone say SYNCRO??????????? </TD></TR></TABLE>
i believeth so.
svtec's Avatar
L D E S
Default Re: WWUD: 5th gear grind ONLY when dumping to a lower gear at higher revs/speeds (Andrew01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrew01 &raquo;</TD></TR><TR><TD CLASS="quote">put some GM syncromesh in the gear box and see what happens, should take care of that little grind. </TD></TR></TABLE>
not if it truely is the synchro.
i tried that with my civic and it still grinds.
Old Feb 19, 2004 | 04:36 PM
integraGSR1's Avatar
if it is the synchro, it won't do any harm. as long as you rev match, you do even need synchro's. older domestics dont even have them. i say save up your money for something else. my 4th gear is out also.
Old Feb 19, 2004 | 05:02 PM
LSTEG96's Avatar
i do believe they all meant SEARCH tho, as this has been covered extensively
Old Feb 19, 2004 | 05:14 PM
Xymox007's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">
i do believe they all meant SEARCH tho, as this has been covered extensively</TD></TR></TABLE>
Well aware of the indications of my problem. I was just curious to the degree of caution I should take.
sle3py_se3z
Sep 20, 2010 03:06 AM
CR3X
13
Oct 25, 2007 01:56 PM
integlover
Jul 13, 2007 01:55 AM
MTR.18
Mar 27, 2005 08:11 AM
Surfer_Sandman
Nov 17, 2004 05:43 PM
