TRANSMISSION FLUIDS?
Old Feb 19, 2004 | 01:52 PM
hookeduphatch95's Avatar
Default TRANSMISSION FLUIDS?
can any1 tell me exactly what is the best type and howm much do i need to fill an empty transmission. i have a 96 b16a w/ a 96 civic si transmission.
Old Feb 19, 2004 | 01:55 PM
Spade's Avatar
Default Re: TRANSMISSION FLUIDS? (hookeduphatch95)
Honda Manual Transmission Fluid.
Old Feb 19, 2004 | 01:57 PM
ekb18cCivic's Avatar
Default Re: TRANSMISSION FLUIDS? (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade &raquo;</TD></TR><TR><TD CLASS="quote">Honda Manual Transmission Fluid.
</TD></TR></TABLE> you can use that but i give it a only cause i love .... GM synchromesh!!! this **** is the best.. it gives more protection then the honda fluid does!!.. i think you need something like 2.8 quarts.. to fill it.. i dont remeber .. def dont need more then 4
Old Feb 19, 2004 | 02:00 PM
tilt's Avatar
ive used honda mtf, redline mtl, gm synchromesh, gm fm synchromesh... quite honestly they all get the job done. I do like redline and gm a tad better though.
Default Re: TRANSMISSION FLUIDS? (ekb18cCivic)
how much does it take? any ideas? i would guess like 2 quarts?
Old Feb 19, 2004 | 02:06 PM
CivicSiRracer69's Avatar
fill it from the VSS and pull the plus in the tranny fill the tranny from the top till it drips out from the fill hole on the side of the case
Old Feb 19, 2004 | 02:09 PM
Default Re: TRANSMISSION FLUIDS? (civiksiracer1)
awsome. thanks guys.
Old Feb 19, 2004 | 02:14 PM
Ricey McRicerton's Avatar
A D series tranny is 1.8 qts ( I know this for sure). A B series tranny is 2.5 (I think.)
Old Feb 19, 2004 | 02:19 PM
Default Re: TRANSMISSION FLUIDS? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">A D series tranny is 1.8 qts ( I know this for sure). A B series tranny is 2.5 (I think.) </TD></TR></TABLE>.. i think mine took like over 2... i changed my d-series tranny fluid 15k ago .. i may remeber wrong..... we'll see how much my b series takes this spring.. im pretty sure its like 2.8
Old Feb 19, 2004 | 02:28 PM
According to the Helms, it only takes 1.8 (and that's how much I put in mine when I changed it as well).
Old Feb 19, 2004 | 02:38 PM
sirmugen3's Avatar
motor oil or Honda Manual Transmission Fluid will work
Old Feb 19, 2004 | 02:44 PM
BauleyCivic's Avatar
Risky Business
Default Re: TRANSMISSION FLUIDS? (sirmugen3)
Old Feb 19, 2004 | 03:01 PM
skip.two's Avatar
Default Re: TRANSMISSION FLUIDS? (BauleyCivic)
there it is . great stuff
Old Feb 19, 2004 | 03:05 PM
Default Re: TRANSMISSION FLUIDS? (jL iLLuZiOnz 9)
i got pennzoil syncromesh. i hope it is the same thing or close enough
Old Feb 19, 2004 | 03:06 PM
moondoggy's Avatar
anyone knows if there is any difference between AC delco/Quaker State Syncromesh to the GM syncromesh? they dont carry the GM stuff here anymore
Old Feb 19, 2004 | 03:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirmugen3 &raquo;</TD></TR><TR><TD CLASS="quote">motor oil </TD></TR></TABLE>
Old Feb 19, 2004 | 03:13 PM
WONG FRIED RICE's Avatar
u have a honda, might as well use honda stuff no?
Old Feb 19, 2004 | 03:14 PM
EG2 SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18cCivic &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Before Honda released their own line of MTF 10-30 motor oil was specified for use in their manual transmissions.
Old Feb 19, 2004 | 03:15 PM
Risky Business
Default Re: TRANSMISSION FLUIDS? (JDMB16ACRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMB16ACRX &raquo;</TD></TR><TR><TD CLASS="quote">
u have a honda, might as well use honda stuff no?</TD></TR></TABLE>
If you dont want to eliminate grinds, honda **** is THE COOLEST y0 M4dd h4x0rz
ghettochild's Avatar
Default Re: (moondoggy)
ive heard the GM **** is some pretty good ****
Old Feb 19, 2004 | 03:31 PM
EG2 SiR's Avatar
Default Re: (ghettochild)
good readin'
https://honda-tech.com/zerothread?id=641177
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">
If you dont want to eliminate grinds, honda **** is THE COOLEST y0 M4dd h4x0rz</TD></TR></TABLE>
i'm guessing you've had problem with grinding b4 using honda fluids? From my experience, i haven't had any problems with grinding after using honda MTF.
Old Feb 19, 2004 | 03:41 PM
i'm guessing you've had problem with grinding b4 using honda fluids? From my experience, i haven't had any problems with grinding after using honda MTF.</TD></TR></TABLE> yeah but go put gm in your tranny you can feel the difference when shifting.. and yes i knowthey used to use motor oil but i give it a
dc5 kid
12
Nov 2, 2007 12:17 PM
iNetForce
13
Feb 13, 2006 04:46 PM
Thanks knightsport!
Jun 8, 2005 09:54 AM
hillbillybob
Feb 23, 2005 05:27 PM
playAho
Apr 2, 2003 07:28 PM
