Porsche 944 brake calipers
Old Feb 19, 2004 | 01:31 PM
AROD's Avatar
Default Porsche 944 brake calipers
Has any on fit 944 turbo calipers on a integra?? anyone?can you make them fit???
Old Feb 19, 2004 | 01:34 PM
TEXN3's Avatar
Default Re: Porsche 944 brake calipers (1.83Tc)
why?
Old Feb 19, 2004 | 03:28 PM
svtec's Avatar
L D E S
that screams tons of money. i'm sure that it could be done, but why?
Old Feb 19, 2004 | 03:43 PM
Kendall's Avatar
If you were to do this, I wouldn't use the standard 944 calipers, I'd use the calipers from the Turbo model, or maybe from the 928. It can be done, but you'll have quite a chunk of money invested in custom mounting brackets and custom rotors that both fit the Integra, and are the required thickness for the Porsche calipers (which Brembo manufactured).
Old Feb 19, 2004 | 08:11 PM
AROD's Avatar
do the sell upgrade rotor that i can use with theses calipers???
Old Feb 19, 2004 | 08:35 PM
95 integra's Avatar
Default Re: (1.83Tc)
supposedly you can use the 4 piston brembos from the boxster...cooltech used to sell a upgrade that came with these, but thats about all i know for fabrication.
Old Feb 19, 2004 | 09:31 PM
patmcd's Avatar
Default Re: (95 integra)
Might I ask why? Im sure it can be done, with enough money thrown at it. You could probably just buy an aftermarket brake kit for cheaper than trying to fit those calipers on.
Old Feb 20, 2004 | 08:18 AM
TEXN3's Avatar
Default Re: (patmcd)
i think it would be cheaper/easier to do a 5-lug upgrade from the Type-R and then do a Legend or NSX caliper/rotor upgrade to that. it would all fit and be a great braking system.
hell, just good pads will do you wonders.
Old Feb 20, 2004 | 09:11 AM
Xymox007's Avatar
Default Re: (texnteg)
Old Feb 20, 2004 | 09:21 AM
AROD's Avatar
i already have the brake calipers they were 100, i can fabricate the brakets. All i need is the rotors, im going to see if i take the porsche rotors and drill new holes to fit them in. Its going to be cheaper than buying 1,000 brake kit.
And they are going to look sick
Old Feb 20, 2004 | 10:15 AM
patmcd's Avatar
I think that by drilling new stud holes in the rotor you are really going to hurt the strenght of them.
Old Feb 20, 2004 | 10:35 AM
trix121's Avatar
Default Re: Porsche 944 brake calipers (patmcd)
and possibly crack them, Id hate to see that happpen when trying to brake 80-0
OUCH!
Old Feb 20, 2004 | 11:50 AM
locass316's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.83Tc &raquo;</TD></TR><TR><TD CLASS="quote">i already have the brake calipers they were 100, i can fabricate the brakets. All i need is the rotors, im going to see if i take the porsche rotors and drill new holes to fit them in. Its going to be cheaper than buying 1,000 brake kit.
And they are going to look sick</TD></TR></TABLE>
your not buying it just to look "sick" are you?
Old Feb 20, 2004 | 12:06 PM
TeamSTEALTH GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">supposedly you can use the 4 piston brembos from the boxster...</TD></TR></TABLE> i've seen this before, on a CRX and a EK... the calipers are like $250(a pair) at a porsche junk yard. Not sure what rotors were used tho..
Old Feb 20, 2004 | 12:53 PM
TEXN3's Avatar
Default Re: (locass316)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locass316 &raquo;</TD></TR><TR><TD CLASS="quote">
your not buying it just to look "sick" are you?</TD></TR></TABLE>
wanna lay a little wager? oh wait...we'd be betting the same thing. damn.
Old Feb 20, 2004 | 07:00 PM
AROD's Avatar
no, im not putting them in b/c they are going to be sick , i need them to stop ill be doing 130mph in the 1/4 mile and i need to stop, but i don't want ot spend 1000 on a kit when i can use these calipers and make my own custom kit
Old Feb 20, 2004 | 07:04 PM
Kendall's Avatar
I have to emphasize the importance of correct rotor thickness. I suggest you contact a company like Brembo and have them custom make you a set of rotors that will fit your car, and are the proper thickness. Then the only problem would be mounting, which could easily be sorted out with a good welder. You may want to take it to a performance brake specialist to see if the brake balance needs to be adjusted and to see if you need a different size master cylinder. There are a lot of things to think about when upgrading brakes, that's why most people just leave it to the professionals and buy a premade kit.
Old Feb 20, 2004 | 09:52 PM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patmcd &raquo;</TD></TR><TR><TD CLASS="quote">I think that by drilling new stud holes in the rotor you are really going to hurt the strenght of them. </TD></TR></TABLE>
actually its fine to redrill them, i run redrilled ones w/p a problem and so do plenty of racers.
Old Feb 20, 2004 | 10:00 PM
florduhdude's Avatar
Default Re: Porsche 944 brake calipers (Eddiebx)
i'd sell the porsche calipers and get the legend/nsx calipers like someone else suggested. You could swing that for less than a grand
Old Feb 21, 2004 | 06:03 AM
wall of tvs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.83Tc &raquo;</TD></TR><TR><TD CLASS="quote">ill be doing 130mph in the 1/4 mile</TD></TR></TABLE>
I'm going to have to waive the BS flag until you give us details of your car along with pics.
A 130 trap speed in the 1/4 equates to low 11s or high 10s.
Old Feb 21, 2004 | 06:41 AM
AROD's Avatar
my setup has nothing to do with the topic about brakes. ill post another thread with pics and dyno sheets of my car. in shorts its a
B18B fully built/ full built heads more breathing power
direct ports Nos 75-100
gt35r .81a/r exh
2000lb car w/ driver gutted
26/8.5/15 slicks
twin plate
thats all you need to know for now, too much to list thats why ill make another post thanxs
Old Feb 21, 2004 | 12:56 PM
TEXN3's Avatar
you got nawws!!! 130mph in the quarter. uh-huh.
wicked2night
Jan 2, 2007 06:36 PM
hookups214
Dec 28, 2005 09:40 PM
snowblind7x
Dec 21, 2005 09:06 PM
mdixonjam
Apr 17, 2005 08:11 AM
