Did Someone Jizz in my Brake Fluid?
Old Feb 19, 2004 | 01:12 PM
DsCivicEx's Avatar
Default Did Someone Jizz in my Brake Fluid?
Well today I was bleeding my brakes and the right side came out fine but when I got to the front left one I got some bubbles out, then some darker nasty black stuff, then Finally I got like a white creamy looking substance but it disappered after a min..only thing I can guess it was is a bunch of tiny air bubbles. Any guess on what it was?
Old Feb 19, 2004 | 01:14 PM
thenick's Avatar
Default Re: Did Someone Jizz in my Brake Fluid? (DsCivicEx)
yeah my clutch jizzed too. i believe thats the air being trapped in the lines makes the fluid that color. hope you didnt bleed it just once and did it a couple of times, also hope you followed RR,RL,FR,FL pattern
but yes you were correct, it was the air
Old Feb 19, 2004 | 01:15 PM
SloCivicHMM's Avatar
Default Re: Did Someone Jizz in my Brake Fluid? (ixiblindixi)
in the manual it says..
RR, LF, LR, RF....................
Old Feb 19, 2004 | 01:20 PM
Fred n J_v2.0's Avatar
Default Re: Did Someone Jizz in my Brake Fluid? (SloCivicHMM)
start farthest away from the cylinder and work your way up to it.
Old Feb 19, 2004 | 01:23 PM
DsCivicEx's Avatar
well my front where the only ones taken apart but I started FR then FL. And yes I bleed them like 8 times till there was nothing.
Old Feb 19, 2004 | 01:28 PM
thenick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloCivicHMM &raquo;</TD></TR><TR><TD CLASS="quote">in the manual it says..
RR, LF, LR, RF....................</TD></TR></TABLE>
yeah thats weird, my friends shitty crappy *** fucktard pictures shot in the dark during an eclipse haynes manual says so too...
regardless we started farthest away and it worked butters
Old Feb 19, 2004 | 01:32 PM
2point2's Avatar
it was me.
Old Feb 19, 2004 | 01:36 PM
Hmmm I should call honda, but *** long at the air is out....
Bled mine last night, like I mentioned early and it works like BUTTTER too!!
H22A EG6's Avatar
Default Re: Did Someone Jizz in my Brake Fluid? (2point2)
hahaha
it was both of us
Old Feb 19, 2004 | 01:42 PM
Built Beast's Avatar
I have always heard, start farthest away from the MC then work your way there. I don't think the manual is always right because it says to wait for like 7500 miles to change my oil(I will pass on that advice, 3k for me is fine)
tcs8ter
Dec 5, 2007 10:03 AM
JDM_EH2
Jun 1, 2007 04:25 AM
StolenTeg
Sep 5, 2006 05:05 PM
sivik2nr
May 2, 2003 12:36 PM
robbin
May 27, 2002 09:27 AM
