JDM ITR final drive into USDM cable YS1 ???
There is a fair amount of info on YS1 gear swaps out there. You'll need to replace the diff carrier and clearance the case in addition to adding the final drive pieces. If you're not swapping in a GSR/ITR gear set as well, your ratios may be a bit strange, as I believe the 1st gear is replaced with a JDM final drive kit.
B2FiNiTY
Jul 5, 2004 07:23 PM
Black R
Oct 26, 2001 06:38 AM
