Fuel Injectors NEED HELP
Old Feb 19, 2004 | 10:38 AM
m1ndphz3r's Avatar
Default Fuel Injectors NEED HELP
I installed new fuel injectors and it made the car run shitty. Is there some kind of preporation i need to do before installing them. Because it is basically plug and play. If anyone knows please tell me. Right now I am going back to my old ones which werent that bad in the first place...please tell me
Old Feb 19, 2004 | 10:40 AM
Redline130's Avatar
Default Re: Fuel Injectors NEED HELP (m1ndphz3r)
What size were the injectors that you installed? If they were bigger than stock, then more than likely they created a rich condition in the motor.
Old Feb 19, 2004 | 10:44 AM
WONG FRIED RICE's Avatar
yea u gotta let us know what size, but redline is right, if u got bigger, ur probably running too rich, and would need some kind of management to lean it out a little. For ex. a vafc, or safc
Old Feb 19, 2004 | 10:49 AM
Home Skillet's Avatar
Hopefully you're not leaking any fuel. Did you replace the O-rings and apply a lube when you reinserted the injectors in the rail? I ripped one and had a nasty fuel leak and didn't know about it, made it run and hesitate like crap.
Old Feb 19, 2004 | 10:57 AM
m1ndphz3r's Avatar
Default Re: Fuel Injectors NEED HELP (Redline130)
they are stock injectors..... I got them off EBAY so i am thinking it was a ripoff to get them. They are the same as my old ones....right now my friend is changing back to the older ones. But they are stock size....CRX SI
Old Feb 19, 2004 | 11:00 AM
m1ndphz3r's Avatar
Default Re: Fuel Injectors NEED HELP (Home Skillet)
All the gaskets and rings are replaces and we did lube everything. My friend is a professional mechanic, i am just confused (he is working on it right now) but i just wanted to know if there is some kind of prep before installing them. Now it drives with them in but around 25000(rpm) it starts to haul and PUT kinda sound ya know. And sometimes the engine light comes on and it runs shitty all the way through, but i turn the key off (car still running) and turn the key back on and it runs back to normal hauling at 25000.
Old Feb 19, 2004 | 11:11 AM
Redline130's Avatar
I would get the injectors you got off of ebay cleaned and flow tested to make sure that one or more of them isn't stuck open or inconsistently spraying.
Old Feb 20, 2004 | 06:33 AM
crx_88_si's Avatar
do the injectors click REALLY loudly, (your old ones or new ones)?
I've noticed mine are the loudest thing on the engine.
Old Feb 20, 2004 | 09:52 AM
91civicEX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m1ndphz3r &raquo;</TD></TR><TR><TD CLASS="quote">All the gaskets and rings are replaces and we did lube everything. My friend is a professional mechanic, i am just confused (he is working on it right now) but i just wanted to know if there is some kind of prep before installing them. Now it drives with them in but around 25000(rpm) it starts to haul and PUT kinda sound ya know. And sometimes the engine light comes on and it runs shitty all the way through, but i turn the key off (car still running) and turn the key back on and it runs back to normal hauling at 25000.</TD></TR></TABLE>
2500? what code does it throw
johnsc2235
Nov 30, 2013 04:34 PM
HeadPorter
Honda S2000
Jan 14, 2008 08:39 PM
2000d16y7
Jul 16, 2007 01:49 PM
85
Honda Motorcycles
Feb 13, 2007 08:30 AM
GOLDBERG
Oct 20, 2002 06:51 AM
