check engine light with obd1 conversion
Old Feb 19, 2004 | 09:56 AM
thatgsr's Avatar
Default check engine light with obd1 conversion
hey have a 96 gsr with an obd1 conversion. will this cause your check engine light to give you certain codes.
mine is giving me (3)MAP sensor, (8) TDC sensor, (17) VSS sensor, (22) VTEC oil pressure switch.
everthing works right but it is giving me these codes
Old Feb 19, 2004 | 11:17 AM
Kataku2K3's Avatar
Default Re: check engine light with obd1 conversion (thatgsr)
Did you make or buy the jumper? You shouldn't have any CEL if the jumper is correct, seems like something is wrong... Have you tried resetting the ECU again?
Old Feb 20, 2004 | 05:03 AM
thatgsr's Avatar
Default Re: check engine light with obd1 conversion (Kataku2K3)
no i didn't make the jumper harness it is a weapon r harness. pretty cheap it was 100 bucks. but it was put in at a good shop in Dallas because i was getting my VAFC hooked up at the same time.
i did reset the ecu and it is only giving me one code (17) vehicle speed sensor.
i also went to a friends house who also had a 0bd1 p28 and the check engine light would come on but it would not give me any codes.
cannouu
Engine Management and Tuning
Jun 28, 2012 10:17 AM
darkdementshun
Jul 17, 2008 10:29 AM
vietnamezerice
Jul 13, 2008 03:36 PM
mastamind
Feb 18, 2006 10:27 PM
Z6REX-SI
14
Feb 9, 2004 10:40 AM
