Will this clutch fit??
i bought a stage two....centerforce dual friction clutch a while back for an 88...i was planning on putting it in my crx...but i bought a new one....(89)....i called up NOPI and asked if they were the same...they said no, i called honda and asked if they were the same...they also said no...the only thing that was the same was the throw out bearing....
CAN I USE THE 88 CLUTCH FOR THE 89....SINCE THE TRANNYS ARE THE SAME?? I NEED TO KNOW BY UMMM...SAY TONIGHT?? THANKS IN ADVANCE!
o_O
o_O
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black89crxsi »</TD></TR><TR><TD CLASS="quote">and theres no way i can make it fit???
Depends, you can take it to a clutch place and have them change that little hub (part that goes onto tranny main shaft) to an 89-91 hub....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Depends, you can take it to a clutch place and have them change that little hub (part that goes onto tranny main shaft) to an 89-91 hub....
where would i take it to???
</TD></TR></TABLE>where would i take it to???
Are there any places in your area that make custom clutches or refabricate them?
P.S. Try sending a PM to a member here by the name of "MrHeelToe" he knows of a custom clutch maker that might be able to do it for you...
WELL SINCE I CANT USE THIS CLUTCH, IM GOING TO SELL IT...IF YOU INTERESTED CHECK OUT THE THREAD
https://honda-tech.com/zeropost?cmd=fshow&id=10
I3ooS710
Dec 5, 2005 06:33 PM
mekanism
Apr 26, 2005 06:54 PM
