Post Your B20 1/4 Mile Times
Old Feb 19, 2004 | 08:33 AM
KimChiKid's Avatar
Default Post Your B20 1/4 Mile Times
BONE STOCK B20Z in a 1992 hatch with exhaust and good tires approx. high 14's
What are your number?!
Old Feb 19, 2004 | 08:43 AM
93EH6
Guest
Posts: n/a
Default Re: Post Your B20 1/4 Mile Times (KimChiKid)
My buddy has one in his del sol and it runs constant 14.2's with just an intake
Old Feb 19, 2004 | 10:46 AM
all motor b20b's Avatar
See Sig.
Old Feb 19, 2004 | 04:27 PM
KimChiKid's Avatar
Default Re: Post Your B20 1/4 Mile Times (93EH6)
wow how did he manage to pull those numbers?
Old Feb 19, 2004 | 04:50 PM
Group Tenacity's Avatar
B20B - stock bottom end with block guard, stock head with race valve springs, T3/T4E turbo.
12.16@111mph @ 10 psi boost and on slicks, in full bodied 96 civic ex coupe
Old Feb 19, 2004 | 05:35 PM
Quik Chris's Avatar
Default Re: Post Your B20 1/4 Mile Times (Group Tenacity)
13.80 @ 98 @ 5830ft-- N/A. Fastest All-motor FWD Honda time at Bandimere speedway.
Old Feb 19, 2004 | 06:07 PM
fuzzynutz's Avatar
Default Re: Post Your B20 1/4 Mile Times (Quik Chris)
stock b20 dropped exhaust 65 shot: 14.0@102 (street tires)
b20 w/ crower 404's and kamikazi header no exhaust: 13.8@ 100 (bfg's)
stock b20 with revhard stage 2 old school kit in 4 door civic: 12.2@114 (slicks)
turned boost up after that and cracked the sleeves
Old Feb 19, 2004 | 06:51 PM
Quik Chris's Avatar
Default Re: Post Your B20 1/4 Mile Times (fuzzynutz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuzzynutz &raquo;</TD></TR><TR><TD CLASS="quote">
turned boost up after that and cracked the sleeves </TD></TR></TABLE>
I notice that this happens a lot on B20's-- because they're basically an LS block w/ thinner aluminum sections on the sleves. Our B20 did this already.
Old Feb 19, 2004 | 07:20 PM
smokey2.0's Avatar
crvtec 13.5@104.5mph on 15" falken azenis
13.10@106.9 on 13" M&H drag radials!
Old Feb 20, 2004 | 12:10 AM
AussieK24's Avatar
See sig
Old Feb 21, 2004 | 04:37 PM
egvx2001's Avatar
Default Re: (AussieK24)
13.6 b16 head / b20 bottom je pistons full exhaust and cat & full system w full interior w street tires ! STOCK HEAD 88crxSI w full w-w kit
Modified by egvx2001 at 8:05 PM 2/21/2004
Old Feb 21, 2004 | 05:13 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (egvx2001)
91 CRX B20B lower c/r motor, LS tranny, slicks, intake, open header, sk2im 2800ft above sea level 105 deg and alignment and camber was off, 92 LS cams, crappy SS that cause me to miss shift = 15.6 at 86 mph I suck. Better times hopefully this spring.
Blaze
Old Feb 21, 2004 | 07:03 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93EH6 &raquo;</TD></TR><TR><TD CLASS="quote">My buddy has one in his del sol and it runs constant 14.2's with just an intake</TD></TR></TABLE>
I am sorry, but there is NO WAY IN HELL that a stock B20 (non vtec) with just an intake is going to run 14.2 with just an intake. Even if you put that in an 88 CRX HF, you wouldn't see those numbers. That claim is 100% bullshit.
Old Feb 21, 2004 | 09:11 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Post Your B20 1/4 Mile Times (Hybrid93Eg)
I actually know of a guy, not sure if he is still around, he ran 14.3 (CRX) with IHEC and crappy tires. He also had the lower compression B20, he goes by AK CRX or something over on superhonda. But a CRX is lighter then most del sols and it depends so much on track conditions. If he has the time slip he should post it up.
just my .02 cents
Blaze
BTW People keep posting your times, its interesting to see what others run.
Old Feb 21, 2004 | 11:10 PM
SiR831's Avatar
my friend ran 13.8 in an EG
milled head, bull frog cams, chipped ecu, JDM 4-1 header with 2.5 collector, and aem type r cold air intake.
Old Feb 22, 2004 | 07:12 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: Post Your B20 1/4 Mile Times (SiR831)
Stock B20B in a 93 Si coupe (EX in the states) no excuses...I can't drive
15.66 @ 88 mph
Clayton
Old Feb 22, 2004 | 03:57 PM
S13Sean's Avatar
Default Re: Post Your B20 1/4 Mile Times (Clayton)
Clayton,
You left yourself wide open... doesn't a stock Si run 15.8s?? I couldn't resist.
Old Feb 22, 2004 | 09:03 PM
Skip01's Avatar
Default Re: Post Your B20 1/4 Mile Times (S13Sean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S13Sean &raquo;</TD></TR><TR><TD CLASS="quote">Clayton,
You left yourself wide open... doesn't a stock Si run 15.8s?? I couldn't resist.</TD></TR></TABLE>
He has a EX not the Si your prolly thinking of.Single Cam.
Old Feb 22, 2004 | 09:22 PM
Kyoji's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clayton &raquo;</TD></TR><TR><TD CLASS="quote">Stock B20B in a 93 Si coupe (EX in the states) no excuses...I can't drive
15.66 @ 88 mph
Clayton</TD></TR></TABLE>
Someone who has the ***** to admit it. My hat is off to you.
Old Feb 23, 2004 | 05:14 AM
KimChiKid's Avatar
Default Re: Post Your B20 1/4 Mile Times (Kyoji)
wowies!
Old Feb 23, 2004 | 07:35 AM
Gearspeed-Performance's Avatar
B20 vtec stock Z block stock head w/ITR cams/intake manifold/CTR header/spoonTB/4.78 final drive on 22" slicks
13.1 in the quarter
Old Feb 23, 2004 | 09:56 AM
S13Sean's Avatar
Default Re: Post Your B20 1/4 Mile Times (Skip01)
Stock B16a Si-R up here or Si runs like mid to high 15s from what I've seen and driven. I was just bustin his chops. He spends more time policing drag racers than racing so I can't really blame him. I barely have time to complete my own car(s).
Old Feb 23, 2004 | 10:33 AM
quickda6's Avatar
stock B20b/drag3 kit/full-weight integra/slicks=12.40@113
Old Feb 24, 2004 | 10:05 AM
KimChiKid's Avatar
Default Re: Post Your B20 1/4 Mile Times (quickda6)
nice setup I want to get a t3/t4 turbo and just go with low boost what is a good option for that turbo wise and everything else?
Old Feb 24, 2004 | 03:00 PM
desert eagle's Avatar
14.4 @ 96 2.3 60ft
bone stock b20vtec in 90 civic si (full weight)
have not been to the track since rebuilt. (sig)
Modified by B20vtec81 at 8:05 AM 2/25/2004
