1992 D16Z6 Engine Questions
Old Feb 19, 2004 | 06:29 AM
workman92's Avatar
Default 1992 D16Z6 Engine Questions
1. How can I tell if my timing is OFF ????
2.How can I check my timing belt or can I ??
3.how often do I adjust my valves? can i tell if they are out of adjustment??
any help is great
Thanks
Old Feb 19, 2004 | 07:44 AM
samdawgsol's Avatar
New User
Default Re: 1992 D16Z6 Engine Questions (workman92)
buy a haynes or chilton book and problems solved.
Old Feb 19, 2004 | 07:51 AM
ARIZONA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by workman92 &raquo;</TD></TR><TR><TD CLASS="quote">1. How can I tell if my timing is OFF ????
any help is great
Thanks </TD></TR></TABLE>
1. Timing Light
2. Check for frays, cracking, and leading edge tooth wear
3. As per service manual less a new install or excessive chatter from the valvetrain.
Old Feb 19, 2004 | 07:54 AM
BauleyCivic's Avatar
Risky Business
Default Re: 1992 D16Z6 Engine Questions (samdawgsol)
1. Cam timing: If your cam gear and block are not at TDC. Igntion timing: Buy a timing light and adjust the distributor until timing is set at stock.
2. Check it for what? If its there?
3. If you can hear your valves slapping horribly then you need a valve adjustment.
All three of these things you really should have a honda shop manual...order one here: http://www.helminc.com/helm/pr...BBTW1
Or PM me for the online version
Old Feb 19, 2004 | 08:27 AM
suspendedHatch's Avatar
Default Re: 1992 D16Z6 Engine Questions (BauleyCivic)
2. Remove timing belt cover.
Bassy_budz
68
Dec 16, 2013 08:38 AM
EGpowa
Jan 8, 2011 10:49 AM
thunderboy
Aug 21, 2008 05:05 PM
211811518
Sep 21, 2006 07:40 PM
Eibach95Civic
Feb 15, 2003 02:38 PM
