V-Tec Questions ?????????????????????????
Old Feb 19, 2004 | 06:08 AM
workman92's Avatar
Default V-Tec Questions ?????????????????????????
Hey whats up, I have a 1992 Civic SI HB with a D16Z6 and I would like to know if the V-Tec kicks in when you are in neutral and revving the engine
Any help would be awsome
please e-mail back at
workman92@hotmail.com
thanks
Old Feb 19, 2004 | 06:12 AM
Red D Dragon's Avatar
no it does not kick in.. Engine has to be warmed up and it get a reading of the VSS vehicle speed sensor so only kick when your moving or on a dyno..
Old Feb 19, 2004 | 06:14 AM
workman92's Avatar
Default Re: (Red D Dragon)
Also another question?
does v-tec wearout? or is it just computerized and it never does?
Old Feb 19, 2004 | 06:27 AM
Well you might have to clean the vtec solonoid if it gets dirty and the cams wear out a little along with the valve trane. but vtec does not really wear out. its just the computer send a signal to lock the cams into higher lift for more air and fuel.
Old Feb 19, 2004 | 06:40 AM
Shawn C's Avatar
In The Garage
it won't "wear out" but the pins that lock the cams might get gunked up with black stuff (sorry for being so technical). you might want to take the cam follower assembly apart amd clean everything
Old Feb 19, 2004 | 07:12 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: (ShadyEH2)
never tried it but my friend says he hit vtec in reverse? he was bored.
Old Feb 19, 2004 | 07:18 AM
94sol_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShadyEH2 &raquo;</TD></TR><TR><TD CLASS="quote">it won't "wear out" but the pins that lock the cams might get gunked up with black stuff (sorry for being so technical). you might want to take the cam follower assembly apart amd clean everything</TD></TR></TABLE>
think i could get some details on how to clean that **** - - my vtec in my 94 sol seems to only kick in 3/4 of the time - thanks
Old Feb 19, 2004 | 07:41 AM
Spade's Avatar
Default Re: (94sol_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94sol_vtec &raquo;</TD></TR><TR><TD CLASS="quote">
think i could get some details on how to clean that **** - - my vtec in my 94 sol seems to only kick in 3/4 of the time - thanks</TD></TR></TABLE>
Purchase a new gasket from Honda
Unbolt it, remove old gasket, hose that sucker down with carb cleaner.
Install new gasket
Bolt back on.
Old Feb 19, 2004 | 11:39 AM
93EH6
Guest
Posts: n/a
Default Re: (vtecb20coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb20coupe &raquo;</TD></TR><TR><TD CLASS="quote">never tried it but my friend says he hit vtec in reverse? he was bored.</TD></TR></TABLE>
lol i'll have to try that one of these days
Old Feb 19, 2004 | 11:40 AM
Spade's Avatar
Default Re: (93EH6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93EH6 &raquo;</TD></TR><TR><TD CLASS="quote">
lol i'll have to try that one of these days</TD></TR></TABLE>
Not possible, the ECU will not allow it just as the ECU will not activate the solenoid when the wheels are not spinning or the car is warmed up.
Old Feb 19, 2004 | 11:41 AM
ridiculous's Avatar
i might try that, in someone else's car. might be fun
Old Feb 19, 2004 | 12:02 PM
JUGGIEGAILS28's Avatar
I thinks its fun, and scary, popping v-tec in reverse.
Speaking of V-TEC, my vtec opens at 5100 and opens even harder at 5200. This has been happening since i got my skunk2 computer anyone ever heard of this. ITS WEIRD! Your the one that asked about spoon but had the crane right, and your from da ny streets where in ny, i know in my town youll get smoked wit that gay single. V-Tec is how i say it and until you could beat me you can agree or disagree.
Modified by JUGGIEGAILS28 at 9:56 PM 2/19/2004
Old Feb 19, 2004 | 12:08 PM
pwrofdrm's Avatar
Default Re: (JUGGIEGAILS28)
It's VTEC!!!! NOT V-Tec or V-TEC.
Old Feb 19, 2004 | 12:15 PM
EGinNY's Avatar
Default Re: (lax1185)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lax1185 &raquo;</TD></TR><TR><TD CLASS="quote">It's VTEC!!!! NOT V-Tec or V-TEC. </TD></TR></TABLE>
Old Feb 19, 2004 | 12:34 PM
Terrabomb's Avatar
Default Re: (EGinNY)
No it does not. The engine must be at operating temperature and have the tires rolling.
Could you put it in neutral while doing 40 and then engage it? I never have tried.
Old Feb 19, 2004 | 12:47 PM
axhandler's Avatar
There are no "pins that lock the cams."
It's the followers/rocker arms that get locked by the pins. There are three followers pers set of lobes, two followers on the small lobes of the cam and there is one follower on the big lobe and there are 4 sets of lobes. When vtec "kicks in" the vtec solenoid activates and uses oil pressure to move the "pins" and lock the vtec followers.
If the pins get gunked up with black stuff you have seriously neglected your engine. However, if your fairly mechanically inclined you could take the followers off and clean it all out. If you search you can find how to's for replacing cams and such. Those will show you how to remove the follower assembly.
Good Luck
Old Feb 19, 2004 | 01:49 PM
hookeduphatch95's Avatar
Default Re: (axhandler)
i know this from experience. vtec is a min. oil pump, when you hita certain rpm the oil pressure pushes a pin to make your cams move over to use the larger lobes. yes it can get gunked up and stick or not engage at all. on the left hand side of the motor, right behind the distributer there is a small solenoid. take out the three bolts and replace the oil seal. clean out the pin w/ contact cleaner and put back. DONT LOSE ANY PARTS!
Old Feb 19, 2004 | 02:17 PM
hubulk's Avatar
Default Re: (hookeduphatch95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hookeduphatch95 &raquo;</TD></TR><TR><TD CLASS="quote">oil pressure pushes a pin to make your cams move over to use the larger lobes. </TD></TR></TABLE>
wow, learn something new every day.
it actually pushes the pin through the valve rockers binding the 3 lobes (2 low rpm, 1 high) together. it doesn't move the cam shaft over.
Old Feb 19, 2004 | 02:22 PM
ekb18cCivic's Avatar
Default Re: (vsm98civic)
i know there is a few tyhings that your car has to be doin for vtec to kick in.... i dont remeber them so clear though... i know your car has to at normal operating temp... pretty sure you gotta be going over a few MPH.. an i think you gotta be moving foward...
Old Feb 19, 2004 | 02:25 PM
quickdelsol97's Avatar
Default Re: (ekb18cCivic)
If you want to mess with your Vtec you can go buy an MSD rpm switch and hook it up to the solinoid. All it needs is a 12V source. Heck, you can put it on a 5 dollar switch...Not advisable, but possible.
Old Feb 20, 2004 | 02:29 PM
EGinNY's Avatar
Default Re: (quickdelsol97)
Can someone explain why i got this Email????
From: "Chris Hendrickson" &lt;chendrickson@oldmerchants.com&gt; Add to Address Book
To: alwysthtguy69@yahoo.com
Subject: where are you from in NY?
Date: Thu, 19 Feb 2004 12:15:31 -0500
Look at my post in the VTECCCCCCCCCCCC question? POST! Let me know what you think. Youll get smoked!
Edit: I get it now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUGGIEGAILS28 &raquo;</TD></TR><TR><TD CLASS="quote">I thinks its fun, and scary, popping v-tec in reverse.
Modified by JUGGIEGAILS28 at 9:56 PM 2/19/2004</TD></TR></TABLE>
You crack me up.....I beleive it was LAX1185 that has the crane and asked about spoon
and which is it V-TEC or VTEC??????????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUGGIEGAILS28 &raquo;</TD></TR><TR><TD CLASS="quote">Speaking of V-TEC, my vtec opens at 5100 and opens</TD></TR></TABLE>
Modified by EGinNY at 6:46 PM 2/20/2004
maras78
Apr 29, 2016 11:25 AM
B18C5-EH2
Jan 17, 2005 04:00 PM
accord ex
Dec 1, 2003 12:23 PM
SS_Supra
Dec 9, 2002 01:19 AM
