88' civic with 93' ex motor swap question
Old Feb 19, 2004 | 01:30 AM
MPF_supra's Avatar
Default 88' civic with 93' ex motor swap question
ok i kind of need help here..
i've been having many and many people tell me different anwsers..
what ecu will i have to get to get the ex motor going?
what engine wiring harness should i use?
if you can help me with this i would appreciate it..thank you
-mpf
Old Feb 19, 2004 | 08:43 AM
WONG FRIED RICE's Avatar
Default Re: 88' civic with 93' ex motor swap question (MPF_supra)
depending on what u do... but regardless... you'll need a p28 ECU or any other single cam vtec ecu (if there are any others). Ur going to either have to change your existing wire harness to OBD1 wiring, get new OBD1 wire harness, or use a jumper harness to the ecu.
Old Feb 19, 2004 | 02:19 PM
MPF_supra's Avatar
thanks man..
someone was telling me i can use the OBD0 ecu..is it true?
Old Feb 19, 2004 | 02:25 PM
Default Re: 88' civic with 93' ex motor swap question (JDMB16ACRX)
hmm, i think if the obd0 computer supports vtec you could. Actually there might be a way that you could rig the vtec on a computer that doesn't support vtec, i forget....maybe someone else knows?
But in the end, it'd probably be easier just to find a OBD1 p28 and use that?
Old Feb 19, 2004 | 07:42 PM
MPF_supra's Avatar
thanks JDMB16ACRX..
my setup is d16 vtec motor, t25 turbo,hf manifold, custom downpipe, magnaflow exhaust system from a integra (90-93)..
Old Feb 19, 2004 | 09:02 PM
mamaboy's Avatar
Default Re: (MPF_supra)
get yourself the p28...you can splice in the vtec harness into the obd-0 harness and convert to mpfi...you'll need the jumper obd-1 conversion harness....blown90hatch can help you
Old Feb 21, 2004 | 01:37 PM
VRD^don's Avatar
Default Re: (mamaboy)
he's doing a mini-me swap..the only concern that we have is what ecu we need.. been hearing lots of different answers from people and getting confused.
Old Feb 21, 2004 | 06:46 PM
MPF_supra's Avatar
yeah i guess i'll just get the p28 ecu than..
-mpf
Old Feb 23, 2004 | 08:15 PM
90slamcivichb's Avatar
to make it easy for you go get a 88-91 crx si wiring harness and a 92-95 civic ex ecu it should plug right on
Old Feb 23, 2004 | 08:46 PM
-16V-'s Avatar
Default Re: 88' civic with 93' ex motor swap question (90slamcivichb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90slamcivichb &raquo;</TD></TR><TR><TD CLASS="quote">to make it easy for you go get a 88-91 crx si wiring harness and a 92-95 civic ex ecu it should plug right on</TD></TR></TABLE>
u sure
Old Feb 24, 2004 | 04:30 AM
VRD^don's Avatar
im not sure about that buddie..
Old Feb 24, 2004 | 07:50 AM
i'll give u 1000 dollars if u can make that plug right in haha
Old Feb 25, 2004 | 04:57 AM
VRD^don's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMB16ACRX &raquo;</TD></TR><TR><TD CLASS="quote">
i'll give u 1000 dollars if u can make that plug right in haha </TD></TR></TABLE>
i second that..
Old Feb 25, 2004 | 10:11 AM
eric.'s Avatar
25 Year Member
I went with a ZDYNE one wire conversion when I had a D16Z6 in my 91 CRX Si. They take your 2g Civic / 4g Civic's ECU and convert it for VTEC control, costs around $320. Later on I sent my ECU back in for the GOLD SECU conversion when I added on a JRSC.
Old Feb 25, 2004 | 10:34 AM
Blown90hatcH's Avatar
NO NO NO NO NO NO NO NO NO.....Please stop giving out incorrect information. First off, not all 88-91 civic/crx engine harnesses are the same. Secondly, the 88-91 Si wiring harness and 92-95 ecu will not plug into each other! They will not work without SERIOUS modifications. DON'T DO IT.
It is fairly easy what you are wanting to do. Here are the parts list:
Your stock engine harness....rewire for MPFI if needed.
OBD1 D15 Vtec motor, OBD1 D15 vtec distributor and ecu....or P28 ecu.
OBD0-1 Conversion Harness - THIS ONE
4 wire O2 sensor if it didn't come with the motor.
All my harnesses come with detailed instructions for an easy installation. I have done the EF to OBD1 conversion so many times I almost have all the ecu pin outs memorized. I am here to help out if needed. I also have stock P28 ecus in stock.
Jason
SingleCamin
14
Mar 7, 2009 10:14 AM
SingleCamin
Mar 5, 2009 11:57 PM
KRZRICAN
Dec 8, 2008 06:54 PM
Jeff
Aug 5, 2005 08:31 AM
ncstatez28
Jun 21, 2004 08:37 AM
